Clock hook up ? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 27th, 06, 08:28 AM Thread Starter
Clock hook up ?
I need to know what fuse and or a ongoing 12volt line for my new clock for my 72 z/28? Everything is hooked up other then the power wire. Your help would be greatful.
dukeme is offline
post #2 of 5 (permalink) Old Apr 27th, 06, 09:18 AM
Steven
Re: Clock hook up ?
Your clock is probaby a 20A fuse, assuming that courtesy lights or hazards or something similar is probably sharing the same fuse.
sdtsdt is offline
post #3 of 5 (permalink) Old Apr 27th, 06, 09:46 AM Thread Starter
Re: Clock hook up ?
So, I assume this is a constant 12 volt current? Positive to what you mentioned, and ground the other?
dukeme is offline
post #4 of 5 (permalink) Old Apr 27th, 06, 02:11 PM
Re: Clock hook up ?
The clock has to be hooked up to a hot wire at all times so that it will work even though the ignition switch is in the off position. Try running a wire to one of the fused terminals on your fuse block that has constant power. The other wire can be grounded anywhere on the body of the car.
Camaro buds until the end!!!
Camaro Dave is offline
post #5 of 5 (permalink) Old Apr 28th, 06, 08:38 AM Thread Starter
Re: Clock hook up ?
Thanks Dave, I did just that! Works GREAT! Now, on to the Alpine in dash CD. And reccomendations? I think I need to cut the origional inlet for the radio?
dukeme is offline
69 Camaro Bumper Jack Hook Question PaceCarNut Camaro Tech 4 Feb 8th, 06 08:45 AM
How to cut the hole for the clock? davepl Interiors 5 Dec 31st, 05 10:38 AM
Clock repair ... this turned out GREAT .. click Electrical & Wiring 5 Jun 25th, 03 09:10 AM
69 Clock Indy Z11 Electrical & Wiring 2 Oct 1st, 02 05:19 PM
repairing a clock on a 68? 68CMRO Interiors 2 Sep 15th, 01 11:51 AM
