How to remove Alternator fan ? - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 28th, 06, 03:52 AM Thread Starter
Hi everybody,
Can someone tell me the best way to remove an alternator fan ?
How do you hold the shaft still while backing off the 15/16" nut ?
My alternator is fine, but the previous owner put on a chrome fan and I'm taking back to stock.
I searched around but couldn't find a thread.
Thanks in advance.
markr is offline
post #2 of 11 (permalink) Old Apr 28th, 06, 04:02 AM
Re: How to remove Alternator fan ?
Originally Posted by markr
Hi everybody,
Should be a allen hex in the center of the shaft so you need a allen wrench. should be 5/16 if its a older alternator.
Greg U
undee72Z is offline
post #3 of 11 (permalink) Old Apr 28th, 06, 04:06 AM
Jack
If there is no place in the shaft to hold it with an allen wrench, use an impact wrench.
68 camaro SS 350 convertible, 69 camaro coupe
smalblock is offline
post #4 of 11 (permalink) Old Apr 28th, 06, 05:50 AM
What I've done very successfuly is clamp the allen wrench in a vise, put a box end wrench on the nut, then set the alternator upside down on the allen, holds it real good.
post #5 of 11 (permalink) Old Apr 28th, 06, 09:51 AM
mike
The best way is to use an air powered impact gun zip-on/off quickly no need hold anything else. If you don't have one take it somewhere that does.
Hogdaddy is offline
post #6 of 11 (permalink) Old Apr 28th, 06, 09:57 AM Thread Starter
That's what I thought.
No Allen on my unit.
I'll take it somewhere.
Thanks Everyone
markr is offline
post #7 of 11 (permalink) Old Apr 28th, 06, 11:15 AM
The end of the shaft should have an allen socket in it, never seen one that didn't
post #8 of 11 (permalink) Old Apr 28th, 06, 11:24 AM
Vintage 68's Avatar
Cool Re: How to remove Alternator fan ?
Another 'Old'sKool' way of removing a pulley/fan from the shaft - is to clamp an old fan belt in a vise that's wrapped around the pulley so it's held tight and then loosen the nut ( on the impact if you have one...) - this works well on most of the older alt/gen/power steering units that don't have the socket (or allen) provision in the shaft end for holding it.
1968 Convertible
Some trucks
Vintage 68 is offline
post #9 of 11 (permalink) Old Apr 28th, 06, 12:47 PM Thread Starter
Hmm....
Coulda swore the end of the shaft was smooth.
I'll take another look tonight.
markr is offline
post #10 of 11 (permalink) Old Apr 29th, 06, 03:13 AM Thread Starter
You were right.
Odd..the allen socket was plugged with dirt.
I couldn't see it.
But the rest of the Alt looks great.
Odd.
Thanks Again
Markr
markr is offline
post #11 of 11 (permalink) Old Apr 29th, 06, 03:31 PM
I too have done it this way and on the alternators with the dual groove and the nut not accesible using a box wrench I've set the amount of how far up the allen wrench sticks out of the vise to where a 1/2 drive socket can be place over the allen wrench sticking up from the jaws of the vise and then set the alternator down on it to engage both the allen wrench and the socket. Since the allen is through the center of the socket I use a pipe wrench to thentwist and grab the outside of the socket to loosen or tighten the nut.
If you are putting on an original alternator fan it should be all right however I had a customer last year with a chrome one that after the motor was revved to a high RPM the blades bent forward and started chewing up the backside of the belt. At first I thought there was a nick in one of the pulleys creating the damage to the belt. After looking for the problem you could visually see how much thinner the overseas fan was compared to a factory original one.
SOA-Nova is online now
Remove 1st gen clip w/out paint damage JeffLit Body Shop 10 May 23rd, 13 05:48 PM
77 camaro dash removal hideaway Interiors 2 Jan 25th, 06 01:57 PM
What am I doing wrong, trying to do burnouts? ray moore Performance 32 Oct 30th, 05 05:21 AM
Shoot over or remove e-coat on reproduction panels Buildinga55 Body Shop 5 Jun 4th, 05 06:45 PM
WANTED: 67-69 Camaro to install T56 six speed in. Teetoe_Jones Tech 2000 2 Dec 31st, 00 05:23 PM
