Tail Lights - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 29th, 06, 08:51 PM Thread Starter
Tail Lights
I Have A Problem With The Tail Lights On My 68 Camaro.
When I Connect The Wires To My Left Side The Bulb Comes On When Not It The Housing. When I Put The Assembly In The
Tail Light Housing, The Bulb Gets Brighter. When The Parking Lights Are On, Directional And Brake Lights Do Not Work Because The Bulb Is Using The Wrong Element. Grounds Seem Good And Sockets Are New, Did The Same Thing With The Old Socket.
Anybody Have Any Ideas?
PITCHER28 is offline
post #2 of 3 (permalink) Old Apr 29th, 06, 10:09 PM
Re: Tail Lights
Take a test light and see if each one of the pigtails sockets is working. One should work with the parking light and the other with the brake. If one side is not working than double check the grounds. Also is it possible you hooked up the sockets wrong? Switched wires?
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 3 (permalink) Old Apr 30th, 06, 11:10 AM Thread Starter
Re: Tail Lights
Thanks For The Reply.
Sockets Are New, Wires Were Tested Before Install.
Maybe It Is A Bad Ground.
tail and console lights out???? wbeeson23 Electrical & Wiring 9 Jul 23rd, 08 08:32 PM
Tail Lights and Blinker Lights prostreet69camaro Camaro Tech 3 Mar 4th, 06 09:13 AM
69 Lights - what lights come on when? Frost Green 69 Electrical & Wiring 8 Oct 6th, 05 09:45 PM
85' camaro tail lights trevordbs Electrical & Wiring 0 Sep 12th, 05 08:38 PM
camaro tail lights Leo Maciel Electrical & Wiring 3 Jun 10th, 03 04:28 PM
