Installing an AutoMeter Tach - Ignition Switch? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 29th, 06, 10:29 PM Thread Starter
Rob
Send a message via AIM to robe9000
1969 Camaro.
I'm installing an Autometer tach. 4 wires: one to a 12v lighting circuit, one to ground, one to the ignition switch and one to the distributor.
How do I wire the connection to the ignition switch? Do I need to drop the steering column or remove the ignition switch to do so? Also, can I use a standard barrel fuse on this wire? Is there an easier way?
Second question. Do I need a special connector to hook up the "-" on a Delco-Remy HEI Distributor?
Thanks - this site rocks!
Rob - SS350 1969
robe9000 is offline
post #2 of 5 (permalink) Old Apr 30th, 06, 12:57 AM
Steven
stamatisg1977's Avatar
Re: Installing an AutoMeter Tach - Ignition Switch?
hello
welcome to team camaro
first hook up the lighting wire (i believe it is the white one on your tach) to the dimmer switch
second the 12volt wire can be spliced in to the connector that is located on the top side of the steering column sorry cant remember which color wire
third to connect to the distributor all you would need is a female spade connector that is wide enough to fit on the metal prong. also i believe that you would connect it on the right side of the coil i could be wrong
i will recheck everything in the morning when i get home from work and revise my post
steve
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 5 (permalink) Old Apr 30th, 06, 05:05 AM
Originally Posted by robe9000
1969 Camaro
The easiest place is right at the fusebox. There are 4 terminals at the fusebox for added stuff. (see pics below) They are marked BAT, ACC, IGN and LPS. The BAT terminal is always hot, the ACC terminal is only hot when the key is in the accessory or on position, IGN terminal is only hot when the key is in the on position, LPS terminal is only hot when the parking or headlamps are on. Use the IGN terminal for power and the LPS terminal for gauge lighting.
Greg U
undee72Z is offline
post #4 of 5 (permalink) Old Apr 30th, 06, 05:19 AM
Do you need one, no. A standard female terminal you can get at any auto parts store will work. Only problem is they don't have the hook to keep them from being pulled out. If you want the factory style terminal that has the hook you can get them here, about half way down the page.
http://www.americanautowire.com/prod...und_Straps.cfm
The factory style terminals also have the benefit of being idiot proof, you can't but the wire in the wrong terminal as in you can't put the tach wire on the BAT terminal and the BAT wire on the tach terminal. Hope this helps.
Greg U
undee72Z is offline
post #5 of 5 (permalink) Old Apr 30th, 06, 07:13 AM Thread Starter
Rob
Talking Re: Installing an AutoMeter Tach - Ignition Switch?
Wow! thanks guys for all the great info - can't wait to get back from church this morning and put in a new Tach!
Thanks for the speedy replies.
robe9000 is offline
iroc-z tach wiring w/ mallory coil/msd ignition I_HAVE_A_RED_87_IROC-Z Electrical & Wiring 0 Oct 14th, 05 02:24 PM
ignition switch and wiper switch??? badazzbowties Interiors 8 Sep 29th, 05 06:33 AM
99 Wiring Diagram Power Door Lock DONZIGW Electrical & Wiring 1 Aug 16th, 05 10:59 PM
Ignition switch - help on identifying kfinsrud Troubleshooting 5 May 12th, 05 10:49 AM
Info on Autometer gauge swap for Dash, Tach and 67 gauge cluster jknotts Interiors 0 Mar 28th, 01 05:25 AM
