Hidden Ignition Button - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 30th, 06, 04:47 AM Thread Starter
Question Hidden Ignition Button
I have a 69 camaro and I'm getting ready for the Hot Rod Power Tour. For security reasons I want to install a hidden push button switch to start the car. I want to be able to turn the key on but it will not start until the button is pushed. I tried going between the wires on the starter solenoid but that did not work. How can I wire this button in from under the dash? Also do I need to install an inline fuze with the switch? Any help will be greatly appreciated. Thanks ZFINE69
jbrode20012000 is offline
post #2 of 7 (permalink) Old Apr 30th, 06, 05:15 AM
Re: Hidden Ignition Button
I believe 69's would have a clutch safety switch?
You have to push the clutch in to start the car?
Those wires.
post #3 of 7 (permalink) Old Apr 30th, 06, 05:43 AM Thread Starter
Smile Re: Hidden Ignition Button
No I do not have a clutch safety switch. This car was once an automatic converted to a 4 speed. Thanks
post #4 of 7 (permalink) Old Apr 30th, 06, 05:57 AM
ahhh, ok then, better yet.
In whats left of the console harness or the connector to it from the dash harness, there are 2 large purple wires, one with a white stripe. They went to the neutral safety switch and will probably be jumpered together. Switch those. Note, tou'll need a pretty beefy switch, 30 amp or so.,
post #5 of 7 (permalink) Old Apr 30th, 06, 01:43 PM
Steps
My son..18.. boy racer lol shorted out his cigarette lighter eliment, disconnected the lighter from the ciruit then put it in the starter circuit.
So the car starts normal, u just have to push the cigarette lighter in 1st.
To do that on a early camaro, would mean mounting the cigarette lighter so its insulated from the dash...I considered doing it to our 69..had a look.
Doesnt any big deal, changing the screws that mount the ash tray, adding a small insulation strip, and a gashet around the cigarette lighter hole.
2 insulation pionts just to make sure.
Steptoe is offline
post #6 of 7 (permalink) Old Apr 30th, 06, 08:40 PM
Bob
I have a kill switch that is connected to the pos(+) side of the distributor. If the switch is off, the car just cranks.....if it is on, it completes the circuit and the car starts. I am also going with a backup kill switch inline of the Neutral safety switch.
Bob
69vert is offline
post #7 of 7 (permalink) Old May 5th, 06, 09:00 AM
Gene
If you have an MSD ignition box, all you have to do is install a switch to ground the white wire coming out of the box (I think the white wire is supposed to be used with a crank triggered ignition). Anyway, grounding the white wire disables the MSD ignition box.
That is what I did for the Power Tour a couple of years ago. I hid the switch under the hood. You are always popping the hood on the Tour, so its not that noticeable when you go to flip the switch.
1969 Camaro - Intense Blue Pearlcoat/white (Baldwin-Motion paint scheme), stock 6.2 liter L92 with VVT, LS3 intake, Doug's Headers; Tremec TKO, 3.73 12-bolt posi.
gheatly is offline
Start/stop Ignition Button mark67ss Electrical & Wiring 2 Nov 9th, 05 01:39 PM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 11:50 AM
Roller Cam Conversion - Cam Button Silver69Camaro Performance 3 Dec 22nd, 04 02:28 PM
Column ignition help soda Electrical & Wiring 3 Apr 9th, 02 04:07 AM
Ignition switch from button to column budman93 Electrical & Wiring 2 Jun 14th, 01 06:36 PM
