camaro starter help needed! - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 30th, 06, 01:46 PM Thread Starter
Exclamation camaro starter help needed!
i have a 95 camaro and when i bought the car the guy said the starter was kinda wierd and i should replace it soon because it "clicks" sometimes when i go to start it. I went out and bought a brand new starter and it still clicks sometimes like the old one. what could be the problem?
norcallowlife87 is offline
post #2 of 5 (permalink) Old Apr 30th, 06, 03:53 PM
Re: camaro starter help needed!
It could be a lot of things, but probably a bad connection. I'd clean them all (battery and grounds).
go2fast is offline
post #3 of 5 (permalink) Old Apr 30th, 06, 11:01 PM
As go2fast stated, check the connections on the solenoid. If the starter is brand new, then chances are that the problem is not the solenoid but, either faulty wiring or a bad connection to the solenoid.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 5 (permalink) Old May 3rd, 06, 12:12 PM
I just went through this myself. Mine started out clicking and then nothing at all. I would turn the key an would even get a click. Ended up changing the ignition switch. It is located on the top of the coloumn under the dash. I would also check the wire like they said. clean them good. Is it a new or rebuild starter you bought. I can be that its not any good either.
dads95 is offline
post #5 of 5 (permalink) Old May 3rd, 06, 12:50 PM
Steps
Using the factory mounting bolts?
Steptoe is offline
Advice Needed Regarding a 69 Camaro Project sy2873 Restoration Corner 20 Mar 27th, 06 07:01 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 06:53 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
starter problem Marc Troubleshooting 6 Aug 21st, 02 12:59 PM
What is needed to swap a 4 speed to a turbo 350 in a 69 camaro? wildmoose Engine 3 Feb 4th, 00 08:53 AM
