slow blinking turn signals - Team Camaro Tech
post #1 of 4 (permalink) Old May 2nd, 06, 08:05 PM Thread Starter
any ideas where to begin on this...is it the flasher
pfahey is offline
post #2 of 4 (permalink) Old May 2nd, 06, 10:34 PM
Re: slow blinking turn signals
Replace the Flasher first and see if that solves the problem.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 4 (permalink) Old May 3rd, 06, 05:00 PM
JohnZ's Avatar
Could also be either the front or rear bulb is bad, so the system doesn't draw enough current to cycle the flasher at its normal rate.
JohnZ
CRG
JohnZ is offline
post #4 of 4 (permalink) Old May 3rd, 06, 08:23 PM Thread Starter
Thanks, I'll try new flasher first and then check bulbs
pfahey is offline
68 Turn Signals rodutah Electrical & Wiring 7 Mar 12th, 06 05:19 PM
Car off, turn signal on-and blinking fast BW67 Electrical & Wiring 6 Oct 26th, 05 07:23 PM
Littering and Turn Signals TJS69 Bench Racing 12 Sep 7th, 05 04:44 PM
turn signals not working kool Electrical & Wiring 1 Apr 18th, 05 04:51 PM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 03:40 PM
