Fuel Guage hookup (cluster ) - Team Camaro Tech
post #1 of 3 (permalink) Old May 5th, 06, 11:52 AM Thread Starter
I have searched for this awnser with no such luck. My problem is that the wiring harness that im working with was a little chopped and frankly the guage wasent hooked up when I baught the car. I have the TAN wire connected to the rear tailight harness and now....I see no wire to hook up to the cluster hahaha. I was thinking if i should just run the wire directly back to the cluster or is there an easier way? Thanks in advance
Nair is offline
post #2 of 3 (permalink) Old May 5th, 06, 07:31 PM
Re: Fuel Guage hookup (cluster )
look up past the ebrake. You'll see the rear harness that goes back to the trunk running down behind the kick panel. There is a connector there, you may have to pull the harness up a lil to find it. Your tan wire will be there.
post #3 of 3 (permalink) Old May 5th, 06, 11:45 PM
If the plug in for the Cluster panel is all hacked up, you might want to replace the entire under dash harness to avoid problems down the road.
Like Jim said......the tan wire is in the tail light harness that connects to the main harness just above the E-brake handle.
I'm wondering why it was cut in the first place? What were they thinking?
Camaro buds until the end!!!
Camaro Dave is offline
fuel guage again Kdancy Electrical & Wiring 20 Dec 16th, 05 06:07 PM
Anyone have hookup on fuel injectors? kscamaro Troubleshooting 2 Sep 21st, 05 08:28 AM
Do I need a new fuel guage sending unit? Straight-line-69 Electrical & Wiring 1 Sep 11th, 05 11:26 AM
'68 dash cluster harness fuel and turn sigs boodlefoof Electrical & Wiring 6 May 16th, 04 03:48 AM
fuel guage guestion Jbboa Electrical & Wiring 2 Mar 18th, 02 04:47 AM
