turn signals - Team Camaro Tech
post #1 of 4 (permalink) Old May 5th, 06, 08:52 PM Thread Starter
turn signals
i hooked up a powermaster alternator and rewired some stuff,,used the exciter wire from the charge light on the dash, i bypassed what i thought was the old external regulator,,,but for some reason my turn signals don't work now,,,,,any ideas,,,where the heck is the turn signal relay in a 69 camaro?
vegascamaro is offline
post #2 of 4 (permalink) Old May 5th, 06, 11:36 PM
Re: turn signals
Check the fuse first and make sure it isn't blown.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 4 (permalink) Old May 6th, 06, 01:00 PM
Re: turn signals
There is no relay, it's controlled by the direction switch in the column and the flasher unit. I don't see how one is related to the other unless you bumped the bulkhead connector.
go2fast is offline
post #4 of 4 (permalink) Old May 6th, 06, 09:42 PM Thread Starter
Re: turn signals
the fuse is good. it was working fine before i messed around with that block thing that i believe was the external regulator. oh well, i'll keep checking stuff
68 Turn Signals rodutah Electrical & Wiring 7 Mar 12th, 06 05:19 PM
RS brake lights and turn signals Chris1111 Electrical & Wiring 10 Oct 13th, 05 10:35 PM
Littering and Turn Signals TJS69 Bench Racing 12 Sep 7th, 05 04:44 PM
turn signals not working kool Electrical & Wiring 1 Apr 18th, 05 04:51 PM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 03:40 PM
