fuel gauge showing really full - Team Camaro Tech
post #1 of 7 (permalink) Old May 5th, 06, 08:56 PM Thread Starter
my 69 camaro has been sitting for a while, just now starting on it again, thus my 4 posts.
my stock fuel guage, which has always worked fine, suddenly is not only pegged when i turn on the ignition, but goes like 80 degrees further. i had to go through the fuel system as some of the gas had stagnated/varnished, but when i drained the tank, it only had about 3 gallons in it. it is a brand new tank. anyone had this happen, any ideas,,,will it work itself out? or is the float/sender messed up?
vegascamaro is offline
post #2 of 7 (permalink) Old May 5th, 06, 11:33 PM
Re: fuel gauge showing really full
Check your sending unit out. There is a sticky about this at the top of the forum. It will explain how to check the sending unit out, if you need help on how to test the unit.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 7 (permalink) Old May 6th, 06, 05:24 AM
ditto.
That's the classic symptom of an "open" in the sending unit circuit. Could be the sender ground, the sender itself, or the tan wire back to the trunk. The sticky will help you troubleshoot it.
post #4 of 7 (permalink) Old May 10th, 06, 07:52 PM
Jack
How do I find these stickies
Jack
67 Camaro Street car 3300 lbs
Flat Top 406 70cc Edelbrock RPM Heads
Q-jet comp xe268s 2500 stall converter
T-350 12 Bolt Posi 373's Cal-Tracs
60' 1.69
330' 4.950
660' [email protected]
1320' [email protected]
Fast Jack is offline
post #5 of 7 (permalink) Old May 10th, 06, 09:05 PM
Lane
https://www.camaros.net/forums/showthread.php?t=71062
sixtynine is offline
post #6 of 7 (permalink) Old May 12th, 06, 12:47 PM
I just went through this the other day on my 68, same problem, found out my ground wire coming from sending unit broken, repaired the wire and cleaned other end, put tank back up. turned on key and the guage went back to 1\4 tank.
glendalekid is offline
post #7 of 7 (permalink) Old Jun 4th, 06, 12:31 PM
https://www.camaros.net/forums/showthread.php?t=73968
This link should help with the fuel gauge.
1968 that started life and a 6 banger with a PG. Now it's a 350 Holley Terminator EFI with a TKO600, Moser 12 bolt (3.73), Speedtech LCA/UCA, ATS AFX Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff.
eville is offline
Factory Tach and Fuel gauge install 69 wtz10 Interiors 15 May 29th, 18 02:40 AM
Fuel gauge acting up!! Adaz71 Electrical & Wiring 4 Jan 10th, 06 05:07 PM
Fuel gauge Issues. 68camrs Electrical & Wiring 9 Jan 1st, 06 01:50 AM
Fuel Gauge wiring question? y-try Electrical & Wiring 2 May 18th, 04 03:01 PM
Fuel gauge Frank Carvalho Electrical & Wiring 9 Mar 22nd, 02 04:12 AM
