fuel gauge reading reversed - Team Camaro Tech
post #1 of 10 (permalink) Old May 7th, 06, 06:38 PM Thread Starter
My old gauge read correctly when I replaced it with a new autometer gauge. It is allegedly a replacement fir GM 0-90 ohm. the problem is, it now read reverse. Full is empty and empty is full. All I did was hook the sending unit wire to the new gauge and it's now backwards. Any thoughts?
cudaman is offline
post #2 of 10 (permalink) Old May 7th, 06, 07:49 PM
Re: fuel gauge reading reversed
Gauge should have 3 wires. Power, ground and sender. Do you have power and ground reversed?
Greg U
undee72Z is offline
post #3 of 10 (permalink) Old May 7th, 06, 08:40 PM
I'm with Greg
post #4 of 10 (permalink) Old May 7th, 06, 11:03 PM
If the wires are not crossed, then it might be a defective gauge.
Camaro buds until the end!!!
Camaro Dave is offline
post #5 of 10 (permalink) Old May 8th, 06, 03:31 PM
Unless it is a Ford style gauge.
GetMore is offline
post #6 of 10 (permalink) Old May 8th, 06, 06:13 PM Thread Starter
I'm pretty sure the + and - are not reversed. I'll check again though.
cudaman is offline
post #7 of 10 (permalink) Old Jun 8th, 06, 10:07 PM Thread Starter
Now the gauge is reading half full no matter what I do. It moves less than 1/8 tank no matter how much gas I put in or run out. These Autometers are causing me too many problems. Or, maybe it's me causing the Autometers the problems.
cudaman is offline
post #8 of 10 (permalink) Old Jun 9th, 06, 08:00 AM
geneo
The brown wire from the tank sender goes to the "S" terminal on the gauge, key on power to the "I" terminal, ground goes to the "G" terminal, also check your tank ground wire
gene_sc is offline
post #9 of 10 (permalink) Old Jun 9th, 06, 12:12 PM Thread Starter
All check ok.
cudaman is offline
post #10 of 10 (permalink) Old Jun 9th, 06, 06:47 PM
get a new gadge my thoughts
dpickl01 is offline
68 camaro fuel gauge at console issue? 30lbtest Electrical & Wiring 4 Mar 18th, 06 07:50 PM
Fuel Gauge still not working right jackalope Electrical & Wiring 4 Apr 21st, 05 10:26 AM
Fuel Gauge from Autometer.... 2zMax Troubleshooting 4 Aug 11th, 02 01:34 AM
What's required to put an in dash tach in a 69 non tach car? SolidLifters Tech 2002 6 Mar 6th, 02 08:45 AM
fuel gauge woes Joshua Leslie Tech 2001 1 Aug 31st, 01 10:48 AM
