Two black wires unconnected under back seat - ??? - Team Camaro Tech
post #1 of 7 (permalink) Old May 7th, 06, 09:17 PM Thread Starter
Brad
I was poking around the back seat tonight and found two unconnected black wires! It looked like they were attached together, but just disconnected. In a lapse of judgement, i connected them... No no avail...
Any ideas on what they could be from?
How to get the bottom back seat out?
Thanks for any input....
Camaroless and hating it
chedderboy is offline
post #2 of 7 (permalink) Old May 7th, 06, 10:50 PM
Re: Two black wires unconnected under back seat - ???
Speaker wires for the rear deck speakers?
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 7 (permalink) Old May 8th, 06, 09:45 AM
Donald
My '69 has a factory rear speaker on the passenger side, the wire for the speaker is a darker blue color and is routed along the passenger side and up to the rear deck, hidden by the side panel. It does not run under the seat. There is only one wire. Maybe your car had after-market speakers installed?
Donald
'69 SS396, X22, 50/50, 729
3rail is offline
post #4 of 7 (permalink) Old May 8th, 06, 05:49 PM
Turd Fergeson
ZZMike's Avatar
That's my guess, too.
1968 British Racing Green Crossram Camaro Z/28
Double Trouble
2016 Black Corvette Z06/Z07
ZZMike is offline
post #5 of 7 (permalink) Old May 9th, 06, 03:00 AM
Donald
To get the bottom back seat out, there are two "U" shaped clips on at the front, near the ends. You will need to apply a decent amount of pushing backwards against the seat cushion while lifting up. This will release the catch that holds the seat in place. It is a whole lot easier to do if you first take out the front seats, then you have plenty of room to move around.
Hope that helps.
Donald
3rail is offline
post #6 of 7 (permalink) Old May 9th, 06, 03:38 AM
Steps
I prefer doing with front seats in
By adjusting the front seat postion just right...with elbow against front seat one can pressure/lever the very bottom part of the rear seat with the palm of the hand...a couple of well placed/timed jerks between the 2 will unclip the rear base.
Steptoe is offline
post #7 of 7 (permalink) Old May 10th, 06, 11:31 AM Thread Starter
Brad
I just got back from the glass shop and they had the back seats out. The bottom back seat had a little toggle switch screwed into the bottom of the seat. It must have been a speaker switch or a ignition kill switch. It wasn't hooked up, just a remnent of the past.
I sought after the elvusive chassis broadcast sheet, but to no avail.
wire behind back seat MileHigh69 Electrical & Wiring 1 Jan 12th, 06 07:32 AM
69 Rear, Back Seat gwbutch Interiors 4 May 26th, 05 11:27 AM
Back Seat Passenger Side Window Track Failure maddogskip Body Shop 9 Sep 6th, 04 07:08 AM
minitubbed back seat krone35 Interiors 1 May 26th, 04 04:11 PM
Seat back bumpers Gary L Interiors 3 Nov 2nd, 03 08:47 AM
