Help! Gauge and heater lights don't work! - Team Camaro Tech
post #1 of 6 (permalink) Old May 8th, 06, 08:26 AM Thread Starter
Welcome Back - Senior Tech
Just hooked up the guages and idiot lights on my 69 coupe and everything works great... Well almost. The speedo, fuel, and heater lights do not work. I do not know what this could be. They worked before but would slightly dim and brighten every once in a while. When i removed my dash I had to cut the 2 wires that go from the gear selector to the fuel bulb so I could remove the cluster (didn't know the selector could be removed). I reconnected and checked those. So guys whats your thoughts. I need to get this car on the road for a show so any help would be VERY appreciated.
bearcat44 is offline
post #2 of 6 (permalink) Old May 8th, 06, 12:30 PM
Re: Help! Gauge and heater lights don't work!
Did you check the fuse, INST LAMPS fuse. The very short one.
Greg U
undee72Z is offline
post #3 of 6 (permalink) Old May 8th, 06, 12:38 PM
Doug
DougP's Avatar
along with the fuse, check your ground wires and check your headlight switch to make sure its not turned all the way down so the instrument lights don't illuminate
==Doug
Former
owner
Former
owner
Former 2nd
owner (
DougP is offline
post #4 of 6 (permalink) Old May 8th, 06, 05:01 PM Thread Starter
Where all should I have ground wires? I have found the one for the headlight switch, and the one that comes out of the wire loom and hooks to the support in the middle of the metal dash. Also, the fuse looks fine..
As far as the light switch being upside down, how would I have done that? Do you mean when I installed the actual knob?
Finally, I've read about a ground that is supposed to go from the brights indicator on the dash to the screw in the top middle of the dash cluster. Am I reading that wrong or did I just not have one before?
Ah and I don't know how this could be related but i'll add it anyhow. At the moment my radio and wiper/washer switch is not hooked up.
Thanks alot folks
post #5 of 6 (permalink) Old May 9th, 06, 04:07 AM
Never assume by looking, always test. Then you have a direction on where the problem is. First turn on the parking lamps and check both sides of the INST LPS fuse with a test lamp or meter. If one side has power and one doesn't, fuse is blown. If both sides have power, the problem is downstream of the fuse, like a ground or a connection. If neither side has power the problem is upstream. The INST LPS fuse gets its power from the tail lamp circuit, if you don't have tail lamps, you won't have dash lamps. Do the same test with the tail lamp fuse. Tail lamp fuse gets its power from the headlight switch. Hope this helps.
Greg U
undee72Z is offline
post #6 of 6 (permalink) Old May 9th, 06, 05:47 PM Thread Starter
Alright well I fiddled around and have somehow gotten the speedometer and heater lights working but still nothing on the fuel gauge. The light is brand new and I think maybe I have a bad socket. This also works into the gear selector light not working. Any ideas?
By the way the other two lights came on after I reattached a loose wire from the light switch. It was green. Everything else was fine and the dimmers work.
Thanks to you guys for helping me.
Center consol gauge cluster electric camaro Interiors 8 Feb 16th, 06 05:07 AM
Engine Temp Gauge is bouncing.. garfield Engine 2 Nov 10th, 04 03:34 AM
engine swap... temperature issue and air in heater hose lines. JIM68 Engine 13 Jan 28th, 04 04:23 AM
New Heater Core, Now it's Running Hot murrayo Heating & Cooling 8 Sep 10th, 03 04:30 PM
Running power to heater motor Joe G Electrical & Wiring 8 Apr 7th, 01 12:26 AM
