Autometer Tach w\ MSD - Team Camaro Tech
post #1 of 3 (permalink) Old May 8th, 06, 09:12 PM Thread Starter
Lane
Anyone running the Z series tach with a MSD setup.. I purchased a MSD 8360 ready to run dist. and noticed while reading thru the tach instructions Autometer will void warranty if used with MSD coil setup.. Should I buy the box to get the tach output or is this just to protect them from supporting this setup.
http://www.autometer.com/download_instruction/726a.pdf
http://www.msdignition.com/pdf/8360_frm%2023793.pdf
Thanks, Joe
sixtynine is offline
post #2 of 3 (permalink) Old May 9th, 06, 05:22 AM
Re: Autometer Tach w\ MSD
Originally Posted by sixtynine
Anyone running the Z series tach with a MSD setup.. a MSD 8360 ready to run dist.
No, but I did read the instuctions. You need to contact MSD to find out if a tach can be hooked to the coil. The instuctions say nothing about a wiring a tach I am not familier with the 8360 but I am with the MSD6al. When using a 6al nothing but the 6al is wired to the coil as the voltage is stepped up quite a bit (400+ volts) and wiring a tach to the coil with a 6al box is a fast way of killing a tach. ( the reason for the warning from autometer) I don't know if the voltage is stepped up on a 8360. Contact MSD to find out what your options are.
Added info... after looking at the wiring diagram it looks like the tach can be wired to the coil- but don't take my word for it, ask MSD.
Greg U
undee72Z is offline
post #3 of 3 (permalink) Old May 9th, 06, 05:42 AM
See these posts also, from the MSD tech forums
http://www.msdignition.com/forum/sho...ight=8360+tach
Greg U
undee72Z is offline
Sunpro tach and MSD Ignition hookup problem !! mykeg11 Electrical & Wiring 5 Nov 27th, 15 10:57 AM
Tach filter from MSD 69rag327 Electrical & Wiring 1 Nov 23rd, 05 08:35 PM
Tach Wooooosss luccamaro68 Performance 7 Apr 26th, 05 06:14 PM
MSD 6AL and tach ray 1969 Electrical & Wiring 1 Nov 28th, 04 03:03 AM
Info on Autometer gauge swap for Dash, Tach and 67 gauge cluster jknotts Interiors 0 Mar 28th, 01 05:25 AM
