I dont think this is right? - Team Camaro Tech
post #1 of 5 (permalink) Old May 8th, 06, 09:40 PM Thread Starter
Brad
As most of you knwo Ive been fooling around with my wiring system. Im running full console gauges with factory harness's. When I turn the key to the "on" position all my dash lights light up including the console gauges. The dimmer wont dim up and down BUT when I turn the head lights on the dash lights get brighter and my console gauges go out completely. Anyone dely with this? could use some good advise. Brad
I just checked again the rh turn signal is on not blinking with the key in the on position.
Most recent 01/01/10
spideynut is offline
post #2 of 5 (permalink) Old May 9th, 06, 05:56 AM
Re: I dont think this is right?
What have you been fooling with. I am only going to take a guess....
Do you have anything hooked to the INST LPS terminal at the fuse box? If so, what??? If the other end is hooked to a power source, you will backfeed power to the dash lamps. Same thing goes for any wire that go to the dash lamps. If you take a dash lamps power wire (that only has power when the headlamp switch is on) and hook it to a power source, the dash lamps will light (reguardless of headlamp switch position) My .02
Greg U
undee72Z is offline
post #3 of 5 (permalink) Old May 9th, 06, 06:52 PM Thread Starter
Brad
Well I narrowed it down to the fuel gauge kinda. When I unplug the fuel gauge the interior lights etc. all work correctly with the dimmer knob except the lights on the console gauges dont work at all. As soon as I plug in the fuel gauge all the lights on the dash and console light up with the head light switch on or off.
post #4 of 5 (permalink) Old May 10th, 06, 05:21 AM
maybe you have the power wire for the gas gauge crossed with the gauge lamps wire.
Greg U
undee72Z is offline
post #5 of 5 (permalink) Old May 11th, 06, 01:18 AM Thread Starter
Brad
is the dash lights supposed to on and dimm with the headlight switch in park light position? Thats the only way I can get the dash lgihts to work.
