voltage regulator - Team Camaro Tech
post #1 of 2 (permalink) Old May 12th, 06, 03:17 PM Thread Starter
voltage regulator
help! new alternator placed into 68 camro ss 350. it didn't work. new regulator put in didn't charge the battery at first found to be wires mixed up. alternator works regulator works now i can't turn the car off! is it that i need a diode or a new one and replace the one by the regulator? thanks for any help
camro tyler is offline
post #2 of 2 (permalink) Old May 13th, 06, 04:42 AM
Re: voltage regulator
What kind of ignition system? Its a common problem with a MSD ignition. The thing by the regulator is a capacitor, not a diode. For run on with the MSD6al you need to add a diode, see pg 8 here
http://www.msdignition.com/pdf/6%20series/6series.pdf
Greg U
undee72Z is offline
Charging system, external regulator JimM Electrical & Wiring 15 Jan 21st, 20 08:09 PM
Mounting / Grounding Voltage Regulator 3rail Electrical & Wiring 3 Apr 24th, 06 12:29 AM
weird happenings going on with voltage regulator hotrodz/28 Electrical & Wiring 4 Apr 12th, 06 09:04 PM
No voltage regulator Omnipotent Electrical & Wiring 4 Mar 20th, 06 06:06 AM
No gen light, no charging. Almost ready for my first test drive! smith69z Electrical & Wiring 18 Sep 2nd, 05 01:01 AM
