1 or 3 wire alt? - Team Camaro Tech
post #1 of 22 (permalink) Old May 13th, 06, 08:30 PM Thread Starter
Lane
1 or 3 wire alt?
I purhased an alt. at Super Chevy a few months ago and had a brain fart because I realized after I got home with it it has an internal reg. ? is, are there any advantages to changing to a one wire and how difficult is it?
Thanks, Joe.
69 Camaro BB
sixtynine is offline
post #2 of 22 (permalink) Old May 13th, 06, 08:49 PM
click's Avatar
Re: 1 or 3 wire alt?
read up in their tech sections at www.madelectrical.com they tell you both sides to your question
click is offline
post #3 of 22 (permalink) Old May 13th, 06, 08:49 PM
Bryan
According to Mad Electrical (http://www.madelectrical.com/electri...hreewire.shtml) the only advantage to the one-wire is it's easy to hook up.
1968 Camaro, 383 with Dart Pro 1 aluminum heads and roller cam, Holley Sniper EFI with Dual Sync distributor, Muncie M21 4-speed transmission, 3.73 12-bolt Eaton posi differential.
Bry68 is offline
post #4 of 22 (permalink) Old May 13th, 06, 08:52 PM
Bryan Hall
thats what iw as thinking i have a 1 wire and it looks neater and hooks up easier than the other 3 wire i had...both are the same performance wise..both were chrome
My car pics...
dallas car show pics plus some of the cars i am building at work
importkiller69ss is offline
post #5 of 22 (permalink) Old May 13th, 06, 09:13 PM Thread Starter
Lane
Thanks guys.. I have some new reading material now..
post #6 of 22 (permalink) Old May 13th, 06, 10:17 PM
Bryan Hall
check out yearwood speed and cutoms...we get great pricing from there since in our shope we order a ton of stuff...i am not sure how they compare to other..but i get my taylor wires and otehr stuff from them even though they are geared more towards hot rods and classics they have somre really cool chrome and other special stuff...thats where i got my alternator
My car pics...
post #7 of 22 (permalink) Old May 13th, 06, 10:18 PM
Bryan Hall
also in there and in summit you can get a kit to change your 3 wire alt...to a one wire..for pretty cheap
My car pics...
post #8 of 22 (permalink) Old May 13th, 06, 10:31 PM
Jerry R.
jr68's Avatar
I just bought an internal regulator alternator for my 68 today ( 3 wire ) and the plug looks different from the one on my original. Old one on the right . How did you guys handle that ?
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #9 of 22 (permalink) Old May 13th, 06, 11:54 PM
You need to change some of the wiring to use the new alternator
At the old voltage regulator disconnect the plug and tie the blue and brown together and the white and red together. At the alternator blue goes to 1# terminal and the white to the 2# terminal. There are numbers on the back of your new alternator to show which terminal is which (1 and 2). If you don't want to cut any of your original wiring you can buy conversion plugs that make changing from a externally regulated alternator to a internally regulated alternator a plug and play deal, you need part# 27555 from here
http://www.americanautowire.com/prod...rsion_Kits.cfm
Greg U
undee72Z is offline
post #10 of 22 (permalink) Old May 14th, 06, 12:59 AM
Bryan
You can also buy the pigtail connector from pretty much any parts store.
Bry68 is offline
post #11 of 22 (permalink) Old May 14th, 06, 07:29 AM Thread Starter
Lane
ok, silly question.. If you use the pigtail adapter does anything need to be done with the other wiring (external reg. or horn relay)
post #12 of 22 (permalink) Old May 14th, 06, 09:37 AM
The changes noted above still need to be done to the regulator connector. I have seen conversion plugs that will do this for you, just plug it into the harness in place of the regulator
post #13 of 22 (permalink) Old May 14th, 06, 02:14 PM
Correct, either you have to cut and splice the wires as shown above or get the conversion plugs. I always mention the conversion plugs as it gives you the option to go back to a externally regulated alternator if you wish. Important to some if the car is close to stock.
Greg U
undee72Z is offline
post #14 of 22 (permalink) Old May 14th, 06, 06:43 PM
Guess
HwyStarJoe's Avatar
Here's another way to look at it......
https://www.camaros.net/techref/ftecref14.html
HwyStarJoe is offline
post #15 of 22 (permalink) Old May 15th, 06, 11:34 AM
I have the same alt as jr68 has on the left in the pic eccept my mounting holes are in a different spot and mine is chrome with no numbers so I just wanted to make sure that the 1&2 are still the same on mine.also there was a rubber plug covering what is 1$2 on jr68's. I'm sure they are the same I just wanted to double check with you guy's so I don't burn it up.
424shee is offline
Draining battery, Possible alternator Need help! mnm99 Electrical & Wiring 33 Jun 2nd, 06 12:12 PM
1 wire alt question Kwondo1967 Electrical & Wiring 2 May 15th, 05 06:40 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 07:02 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
