My camaro is driving me crazy. - Team Camaro Tech
post #1 of 5 (permalink) Old May 14th, 06, 03:07 PM Thread Starter
My 91 camaro won't start. It turns over. I replaced the distributer and plugs. A friend told me it was the ignition system. I don't know what to do. any suggestions.
rship75 is offline
post #2 of 5 (permalink) Old May 14th, 06, 07:22 PM
Dan
Re: My camaro is driving me crazy.
Need a little more info!
Is it getting fuel to the carb?
Is it electronic ignition or do you have an external coil?
Rack Man is offline
post #3 of 5 (permalink) Old May 14th, 06, 08:10 PM
Steven
If your 91 is stock, do a search on VATs... Are you getting any lights ( engine, security, ??? ).. ALso, make sure that there are no open vacuum lines and that all connectors ( at least the ones you can see ) are attached.
sdtsdt is offline
post #4 of 5 (permalink) Old May 15th, 06, 01:30 AM
Need more info about the car engine size, TPI or TBI. Did you do an engine scan to see if there are any trouble codes stored in the ECM?
Camaro buds until the end!!!
Camaro Dave is offline
post #5 of 5 (permalink) Old May 16th, 06, 04:25 PM
Jeff
I wouldn't be worried about trouble codes at this moment. Is the car even trying to start, or just winding over? First you need to do the basic checks,, see why it isn't starting. Pull a plug wire and hold it near the plug and have a friend crank it over. Does it spark? If so Check for fuel . When you find out if it's fuel or fire you are missing (assuming its not compression, as it most likely is not) message me if you like or post it on here, and you can go from there. A bit of other info will help as well, such as engine size, etc. but either way,, you gotta start at the start. Lemme know, Jeff
Jeff22 is offline
OK Fella's....here it is! 2009 Camaro. Infamous Fifth Generation 195 Sep 8th, 06 06:10 PM
A big thanks to team camaro!!! 68 VT Bench Racing 13 Feb 28th, 06 04:41 AM
2006/2007 camaro? sincityrsss350 Bench Racing 30 Sep 21st, 05 10:19 AM
APC Driving Lights In 69' Camaro third base Electrical & Wiring 8 Jun 10th, 05 08:19 PM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
