funky wiring? - Team Camaro Tech
post #1 of 6 (permalink) Old May 15th, 06, 09:59 AM Thread Starter
funky wiring?
when I turn the wheel to the right the idle goes up and when turned to the left it goes down.any ideas what I should check first?ig If wiggle the wires on the column it does affect anything.
424shee is offline
post #2 of 6 (permalink) Old May 15th, 06, 10:32 AM
Re: funky wiring?
do u have power steering?
I don't think anything electrical could effect the idle speed when you turn the steering wheel.
post #3 of 6 (permalink) Old May 15th, 06, 10:43 AM Thread Starter
Re: funky wiring?
yes I have power steering.
424shee is offline
post #4 of 6 (permalink) Old May 15th, 06, 11:17 AM
Re: funky wiring?
most likely your idle speed is changing due to the load on your engine from the power steering pump
post #5 of 6 (permalink) Old May 15th, 06, 01:30 PM
Re: funky wiring?
That's what I was thinking.
Or you have vacuum lines wrapped around your column
markr is offline
post #6 of 6 (permalink) Old May 15th, 06, 01:42 PM Thread Starter
Re: funky wiring?
alright,thanks guy's I'll check it out.
424shee is offline
Ignition switch wiring problems bwhitfield Electrical & Wiring 4 Jan 10th, 06 08:38 AM
Rewiring the car... mbmmca Electrical & Wiring 13 Nov 23rd, 05 12:27 PM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 11:50 AM
Installing console gauges and wiring. Questions... jumpmaster Electrical & Wiring 7 Aug 23rd, 05 05:36 PM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 04:34 AM
