Electronic Ignition For Dummies - Team Camaro Tech
post #1 of 4 (permalink) Old May 17th, 06, 06:40 PM Thread Starter
I want to replace my points. I've searched the forums and found many threads with recommendations of different products: HEI, Crane XR-I, Mallory, Petronix, etc. My problem is that I have no idea what the differences are in these products. Anyone want to write a little Ignition for Dummies post that actually explains the various options? It would certainly be appreciated by me, and probably others wanting to convert. Thanks in advance.
68DaveV is offline
post #2 of 4 (permalink) Old May 17th, 06, 08:35 PM
Re: Electronic Ignition For Dummies
kinda late for a full blown ignition for dummies, maybe tomorrow if no one else has by then.
The short version:
If you're bucks up, an msd ready to run #8360 is hard to beat, 300 clams.
If you don't mind getting old, send your distributor to Dave, he'll put hei guts on it and send it back ina few months.
If you're poor, all the "conversions" do work, and are pretty close as far as cost and performance, under 100.
If you're really poor, a junkyard hei can be made to work, but by the time you buy wires and recurve it, it will cost as much as the conversion kit and might hit your firewall.
post #3 of 4 (permalink) Old May 17th, 06, 09:34 PM
Dave, If you want to play it safe and go with a EI system, go with the Pertronix Ignitor. A HEI distributor works just as well, but like Jim said you might run into problems with firewall clearance. If you want to upgrade from points and want an easy way of doing it, the Pertronix Ignitor only takes a few minutes to install.
The benefits include.....you never have to adjust points again, better timing control and added Horse power. I have the Pertronix Ignitor and am happy with it.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 4 (permalink) Old May 18th, 06, 08:51 AM
Vintage 68's Avatar
Thumbs up Re: Electronic Ignition For Dummies
Originally Posted by 68DaveV
I want to replace my points...
Here is a good past thread about the conversions - https://www.camaros.net/forums/showthread.php?t=77471
Any of the conversions will install and work well in most uses.
The installation procedure varies slightly by the type of system and it's options. Some require the distributor to be removed, some don't.
IMHO, if you're going to install a system you don't intend to service in the near future (sort of the reason for doing this conversion in the first place isn't it ??? ) then NOW is a good time to pull the distributor and check the Drive Gear, Bearings/Bushings, Advance mechanism and other items - then you won't have to mess with the thing for years...
Each of these systems has slight differences in set-up and function, but they all provide a good reliable replacement to your original point system and require little or no follow-up adjustment or service.
The factory HEI systems are also a very viable way to go 'pointless' and, as stated above, there are several flavors of systems availble from both the OEM and aftermarket suppliers.
As an additional EIS (Electronic Ignition System) "101" - the systems all basicly use an transistor to couple the ground path for the Coil through the distributor and trigger it with a Light or Field (you can read 'magnetic' sortta here if you want) signal amplified via internal circuitry.
Some are wired directly to the original wiring and some require bypassing the original ignition ballast device to provide higher line voltage to the module - the instructions will tell you which way to go.
Hope this helps;
1968 Convertible
Some trucks
Vintage 68 is offline
Electronic ignition conversion rsbecool Electrical & Wiring 14 Feb 15th, 06 06:52 PM
Changing points to electronic ignition converter stevea Electrical & Wiring 10 Jun 16th, 05 10:55 PM
Question about Electronic Ignition 69DZ302 Engine 8 Sep 24th, 04 05:54 AM
Electronic ignition suggestion? Hutch Tech 2000 8 Apr 16th, 01 12:48 PM
Electronic Ignition SB327 Electrical & Wiring 5 Dec 8th, 00 08:25 AM
