Factory tach with MSD 6AL - Team Camaro Tech
post #1 of 6 (permalink) Old May 18th, 06, 10:27 AM Thread Starter
foreverlookin's Avatar
I know this has been asked before but, when I ordered a new wiring engine harness I took the ready to use with an electronic ignition as I thought at a minimum I would convert the original to electronic. Anyway changed direction went to an MSD6AL, blaster coil, and pro-billet distributer. Now I am trying to figure out how to get the tach working as I only have the one wire brownish/rose colored in the engine compartment and when I connect it to the tach output on the 6AL I get nothing.
Is there something else that needs to be connected?
Thanks Steve
foreverlookin is offline
post #2 of 6 (permalink) Old May 18th, 06, 10:41 AM
Darin
Re: Factory tach with MSD 6AL
Timely...I Just did this this weekend.
I'd bet you have the wrong wire...
Remove your instrument cluster and track down which circuit (on the printed circuit-board) is routing voltage to the tach.
Follow (trace) that circuit to the cluster plug.
Then, trace the wire that is connecting to the plug from the plug to into whichever wiring harness it belongs to in the engine compartment...
This is the wire that needs to connect to the tach output of the MSD box.
Plug it into the tach output and you should have tach operation.
Darin Imbriaco is offline
post #3 of 6 (permalink) Old May 18th, 06, 11:20 AM
wut year is your car?
At least on a 68 (not certain about 69, think it's same) the tach signal wire was never part of the engine harness, only one part number for the engine harness regardless of gauges or not.
The tach wire was run separate, directly from the stud on the tach, thru the firewall, to the coil.
Your brown wire is for the oil pressure idiot light, sender installs right next to the distributor.
post #4 of 6 (permalink) Old May 19th, 06, 07:11 AM Thread Starter
Jim, are you saying that there is no connection on the printed circuit board to the tach on a 68? Should I be looking at running a wire off of the back of the tach to the trigger/tach output on the MSD6AL?
post #5 of 6 (permalink) Old May 19th, 06, 10:00 AM
Darin
Regardless, what Jim said WILL certainly work too.
post #6 of 6 (permalink) Old May 19th, 06, 07:54 PM Thread Starter
Thanks for the feedback guys I will try to solve this and other challenges this weekend.
factory tach in 67? GMJoe Electrical & Wiring 0 May 7th, 06 06:52 AM
HEI to MSD 6AL Should I? PinMd Performance 14 Jan 15th, 06 11:20 AM
MSD 6AL and tach ray 1969 Electrical & Wiring 1 Nov 28th, 04 03:03 AM
will original tach work with msd 6a Pat's 69's Electrical & Wiring 3 Nov 22nd, 04 02:40 PM
Tich toch tach / MSD 6AL compatible? 1stgenZ Tech 2000 2 May 11th, 01 05:43 AM
