RS Rear Wiring Harness - Team Camaro Tech
post #1 of 7 (permalink) Old May 20th, 06, 05:31 AM Thread Starter
Question RS Rear Wiring Harness
Are all 67/68/69 rear harneses the same? I need a new harness for my 68 RS and found a good deal on a 69 RS harness. Just wondering if they are the same.
Thanks for any help!
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
post #2 of 7 (permalink) Old May 20th, 06, 10:35 AM
Larry
Re: RS Rear Wiring Harness
Electrically, the 68 and 69 are the same, but the bulb sockets are different. The 67 and 68's ground through the tail light housing. The 69's have a seperate ground wire that splices all tail lights together and grounds them at the truck lock support. Plus, according to the factory electrical diagrams, the 68 harness connects to the main dash harness near the fuse panel. The 69 tail light harness connects to the mid body harness above the left rear wheel well. The mid body harness then connects to the dash harness like the 67 and 68.
You could make it work with new sockets, run your own ground wires, and extend the wires all the way the the dash harness, but the aftermarket sockets that I have tried at the auto parts stores really suck. They don't stay secured in the housings very well. A lot of work, but possible.
Larry
69-er is offline
post #3 of 7 (permalink) Old May 20th, 06, 11:50 AM
Scott, you can buy a rear harness for around $100.00 for your car. I don't know if it would be worth the hassle of changing the sockets and redoing some of the wiring just to save money. The 69 harness is about $20 less than the 68, but would still have to be modified. I would go with the correct harness. Just my opinion.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 7 (permalink) Old May 21st, 06, 05:31 AM Thread Starter
Thumbs up Re: RS Rear Wiring Harness
Thanks Guys....Looks like Dave has the right answer. Changing all that isn't worth the $30. savings
Here is one on me
67 RS/SS Pictures
cpodeep is offline
post #5 of 7 (permalink) Old May 21st, 06, 07:33 AM
Larry
If you are not in a hurry, you still might find a good buy for a 69 harness on eBay.
Larry
69-er is offline
post #6 of 7 (permalink) Old May 25th, 06, 12:20 PM
Tony
Scott, I need a 69 RS rear lamp harness--can you put me in touch with the seller? Thanks, Tony
RPOL72 is offline
post #7 of 7 (permalink) Old May 26th, 06, 06:21 AM Thread Starter
Tony,
Sorry...it was on Zbay and is now gone.
67 RS/SS Pictures
cpodeep is offline
Is the Under dash wiring harness fron Classic Ind worth it? POCKER Electrical & Wiring 2 Apr 24th, 06 10:02 AM
67 rs wiring harness 67ssrs350 Electrical & Wiring 2 Apr 2nd, 06 07:32 PM
New wiring harnesses - help please! Eric Kammerer Electrical & Wiring 3 Jun 22nd, 05 09:48 AM
Wiring Harness ???? bdcole_51 Electrical & Wiring 1 Oct 27th, 04 12:43 AM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 04:34 AM
