1968 voltage regulator question - Team Camaro Tech
post #1 of 6 (permalink) Old May 21st, 06, 05:56 PM Thread Starter
I have a 68 camaro with what appears to be the original voltage regulator. I am upgrading the engine compartment with lots of chrome. I bought a chrome voltage regulator from Ricks; but when I put it on the battery is not charging. I put the old one back on and the battery is charging just fine. I know its possible to get a bad regulator but is there a way that I check the new one with a meter before sending it back to Ricks.
orange 68 is offline
post #2 of 6 (permalink) Old May 21st, 06, 06:01 PM
Re: 1968 voltage regulator question
if your old one works fine why not swap covers and call it done?
If you do want a new regulator, get a wells vr715 from autozone. This is an elevtronic replacement for the stock mechanical regulator. you can use the chroime cover on it, too.
post #3 of 6 (permalink) Old May 21st, 06, 06:08 PM Thread Starter
The old one has rivets holding the cover on but I guess I can drill them out and swap covers as you suggested. Or would I be better off replacing the old regulator since it is old. (yes it does still work good).
Thanks Jim for the quick reply
post #4 of 6 (permalink) Old May 21st, 06, 08:08 PM
I would just convert to a internally regulated alternator if you are going to replace anything. Very easy to do. Only reason to keep the external charging system is if it already works or its a 100% correct car.
Greg U
undee72Z is offline
post #5 of 6 (permalink) Old May 21st, 06, 10:22 PM
If the one from Rick's doesn't work, I would send it back. If your old one is working and the new one does not, you can safely say that you got a bad regulator from ricks. Get another one from Rick's with a chrome cover and keep your old one as a spare.
Camaro buds until the end!!!
Camaro Dave is offline
post #6 of 6 (permalink) Old May 22nd, 06, 03:59 AM
Did you change over the the ground wire from the older regulator to the new regulator chassis?
Regulators are rubber mounted and require a ground strap on one stud or a separate black ground wire. Usually, new regulators do not come with the ground wire and do not come with the radio interference filter (the round condensor).
Everett#2390 is online now
1968 Camaro Wheelwell Moulding Differences - Observation elcamino72 Body Shop 9 Nov 4th, 16 10:35 AM
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
Voltage fluctuations fletcher969 Electrical & Wiring 6 Dec 16th, 05 11:37 AM
Battery Cables, Amp Gage, Voltage Gage, Voltage Regulators, Alternators ...oh my!! Robert Stacho Electrical & Wiring 34 May 23rd, 02 12:30 PM
1968 Manual Steering Gears Kyvox Tech 2002 8 Apr 21st, 02 08:58 AM
