Testing Gages - Team Camaro Tech
post #1 of 14 (permalink) Old May 21st, 06, 07:04 PM Thread Starter
foreverlookin's Avatar
Testing Gages
My saga continues.....temp and fuel gages on my 68 console will not work. On the fuel gage, I tested the sending unit when I changed the tank with an ohm meter and it worked great. I have 12v on the pink feeding the one side of the console gage and about 3.5 volts if I measure accross the gage, if I disconnect the sending unit the voltage jumps to about 6.5 volts. I triple checked the ground and it is good...any hints on what to look for next or is the gage screwed?
On the temp gage I bought a new sensor for the block and I do not know what to look for next.
The gages are original so I am leaning towards the fact that they are both screwed.
Any hints would be appreciated!
foreverlookin is offline
post #2 of 14 (permalink) Old May 21st, 06, 07:51 PM
Re: Testing Gages
Both gauges have 3 electrical connections, power, ground, and sending. First be sure both have power and are grounded. I am not familer how they are grounded (whether by a wire or the gauge itself, some else may chime in on this) after having proper power and ground, you can test the gauges with the sending wire. With the sending wire not connected to anything fuel should be pegged to "F" and temp to "C". With the sending wires grounded fuel should be pegged to "E" and temp to "H". If this happens, gauges are working correctly.
Greg U
undee72Z is offline
post #3 of 14 (permalink) Old May 22nd, 06, 06:57 AM Thread Starter
Re: Testing Gages
The gages appear to be fine then as they test out as you described above.
I guess I will have to concentrate on the sending units then. I may have damaged the tank unit installing it and who know if the temp sending unit was defective from the start.
post #4 of 14 (permalink) Old May 22nd, 06, 12:32 PM
Re: Testing Gages
The temp sending unit must be for gauges. With a idiot light sending unit, the gauge would never move till the car overheated since it is basicly a on/off type for the light. To test temp sending units for gauges see here
http://www.madelectrical.com/worksho...mp-gauge.shtml
You also post on the Chevelle board too?
Greg U
undee72Z is offline
post #5 of 14 (permalink) Old May 22nd, 06, 04:06 PM Thread Starter
Re: Testing Gages
I am getting more and more confused trying to solve this problem. I took the temp sending unit, which I had bought brand new, and heated the element to see if I would get a change in resistance across the sensor which I did. I had another used one around and it was almost identical in the changing resistance with the addition of heat.
I would be curious to know what the voltage should be after the gage and at the plug in the trunk that connects to the sending unit, also what it should be at the temp sending unit on the motor.
If anyone could post the above info I would appreciate it.
post #6 of 14 (permalink) Old May 24th, 06, 08:13 AM Thread Starter
Re: Testing Gages
I have troubleshoot this to death and I think that the fuel gage is toast. It will cycle as undee72z suggested but when I dug a little deeper and read what Jim had cut and pasted in from the Chevelle site in the electrical troubleshooting and followed that process through it will not register any level. I checked the resistance at the connection in the trunk and got 52 ohm's about 1/2 tank. Disconnected at the gage and measured it and got almost the same 51.8 ohm's, when I connect it back up to the gage it drops to 15 ohm's. And like I posted earlier the voltage drops significantly when it flows through the gage.
I will change the gage and see what happens.
post #7 of 14 (permalink) Old May 24th, 06, 10:03 AM
Re: Testing Gages
give it a try if you have one handy, but...
making a resistance measurement with the circuit connected to the guage is putting the internal resistance of the guage into a parallel circuit with the internal resistance of the sender. That's what is changing the reading, tho I do not know what that correct reading would be.
post #8 of 14 (permalink) Old May 25th, 06, 04:17 AM
Re: Testing Gages
Maybe you have a power or ground problem. Check the voltage, at the power wire at the gauge with everything hooked up. Voltage should be close to battery voltage. If its a lot lower, you have a power problem.
Greg U
undee72Z is offline
post #9 of 14 (permalink) Old May 25th, 06, 06:55 AM Thread Starter
Re: Testing Gages
The temp and fuel gages are fed from the same pink wire and prior and that voltage reads the same as the battery when disconnected from the gage. When I plug in the gage and read the voltage it drops to about 6.5V with the sending unit disconnected and when I reconnect the sending unit it drops again to around 3v. This is why I am leaning towards a gage issue.
By the by I have checked the grounds and even ran an express line back to the battery to make sure I had an adequate ground.
post #10 of 14 (permalink) Old May 26th, 06, 01:26 AM
Re: Testing Gages
If I am reading this correctly and you are testing the pink to ground with a meter, with the gauges hooked up....
Thats a huge drop. You must have a bad connection somewhere. Try using a temp wire from the battery for power (use a inline fuse for safety) You should still have battery voltage. Even the starter onlys pulls system voltage down 2 or 3 volts. I would bet the gauges will work fine with good power.
Greg U
undee72Z is offline
post #11 of 14 (permalink) Old May 26th, 06, 04:48 AM
Re: Testing Gages
what Greg said
! If those were good reading, you seem to have a high resistance connection in the pink wire. Strong possibilities would be the console connector and the fuse utself.
post #12 of 14 (permalink) Old May 26th, 06, 11:07 AM Thread Starter
Re: Testing Gages
I am getting real confused here.
I have 12v on the pink feed to both fuel and temp circuits. When I plug the pink power onto the fuel gage the voltage through the gage drops to 6v and drops even further to about 3.5v when I reconnect the sending unit in the trunk.
The voltage deviates big time, 50% when I plug it into the gage. The resistance is accross the gage.
I will run a power feed, fused, to the gage from a different source and try it to see how it works.
post #13 of 14 (permalink) Old May 27th, 06, 12:01 AM
Brad
Re: Testing Gages
[QUOTE=I have 12v on the pink feed to both fuel and temp circuits. When I plug the pink power onto the fuel gage the voltage through the gage drops to 6v .[/QUOTE]
Im getting the EXACT same reading on my repop gauge! I've tried every ground possible. We need to know what's the voltage across a "working" gauge. I have my mouse on a buy it now button for a new temp gauge. Hope someone can chime in.
Most recent 01/01/10
spideynut is offline
post #14 of 14 (permalink) Old Jun 12th, 06, 07:15 PM Thread Starter
Re: Testing Gages
Problem was old gages installed new ones and everything works fine...nice to know how much gas I have!
Electrical Problems with Floor Gages and TACH SS468CAMARO Electrical & Wiring 7 Mar 18th, 06 10:47 PM
Console gages (temp/amp) not working? chedderboy Electrical & Wiring 5 Jan 18th, 06 04:06 PM
Hybrid Testing 250 MPG Wayne Bench Racing 27 Oct 20th, 05 12:24 PM
68 camaro gages ks2kwik Troubleshooting 1 Mar 18th, 03 11:31 AM
