How to tell if its OER gauge? - Team Camaro Tech
post #1 of 4 (permalink) Old May 22nd, 06, 12:19 AM Thread Starter
Brad
I bought a like new repo set of factory style guages off of E-bay. I noticed in Ricks catolog that only OER repos dont use an external gas gauge resistor. Mine fuel does not have one but my temp. gauges does.
I was thinking that might be my problem. My problem is fuel reads past full with the key on. When I ground the brown wire same thing. I tested my sender and it checks out o.k.
While we're on the subject my Temp is doing the same thing. Its pegging to Cold when the key is on sender grounded or not. Any help on anyone of the questions would be great.
Most recent 01/01/10
spideynut is offline
post #2 of 4 (permalink) Old May 22nd, 06, 12:46 PM
Re: How to tell if its OER gauge?
Either its a power, ground, wired incorrectly or the gauge is defective. Be sure it has power (key is on) and the gauge is grounded, and its wired correctly.
Greg U
undee72Z is offline
post #3 of 4 (permalink) Old Jun 5th, 06, 11:15 PM Thread Starter
Brad
For the record: I bought a new temp gauge and it works perfect. And for the fuel gauge (this may sound weird) but I replaced the whole turn signal cam in my column and it fix the short I was having to my fuel gauge.
post #4 of 4 (permalink) Old Jun 6th, 06, 04:12 AM
I've still got about a dozen more of those OER temp gauges if anybody needs one, glad it worked out for you Brad!
kz1000ltd is offline
OER Temperature Gauge Pegged Hot hairboy Electrical & Wiring 0 Jul 26th, 05 06:39 AM
OER Temp Gauge braber427 Electrical & Wiring 4 Jul 13th, 05 07:37 AM
Another Fuel Gauge problem sgaylord Electrical & Wiring 7 Feb 4th, 03 11:11 AM
fuel gauge reads over full... mike brown Troubleshooting 10 Aug 4th, 02 08:29 AM
What's required to put an in dash tach in a 69 non tach car? SolidLifters Tech 2002 6 Mar 6th, 02 08:45 AM
