Should idiot lights still work if you have console gauges? - Team Camaro Tech
post #1 of 4 (permalink) Old May 22nd, 06, 10:27 PM Thread Starter
I was replacing my instrument cluster today, and I noticed that the bulbs are missing from the idiot lights for FUEL and OIL. My car has console gauges. So two questions:
1) Should the idiot lights for fuel and oil have bulbs and be operational if you have console gauges?
2) Since the sensors for gauges are analog and different than the on/off sensors for lights, how could/do they make both work?
Thanks,
('69 Camaro RS/SS)
1969 RS/SS 396 Camaro [MPFI Supercharged 502 Under Construction]
2007 427 Z06 Corvette
1969 Pontiac 2+2 427/390
2003 CL600 BiTurbo Renntech Stage III (635hp - [email protected]) [Sold!]
2006 Range Rover Eaton Supercharged
davepl is offline
post #2 of 4 (permalink) Old May 23rd, 06, 03:45 AM
Re: Should idiot lights still work if you have console gauges?
You only have the fuel light if you have the console guages, and no the oil light should not work with the guages since the oil line to the guages attach to the same spot on the block as the old sender does.
The oil gauge in the console is mechanical, and has a plastic tube that connects it to the top of the block. The fuel light is lit by a low fuel module that is attached to the bottom of the fule gauge in the console, it porvides a connection to ground when the fuel is down to about 2 or 3 gallons.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 4 (permalink) Old May 23rd, 06, 01:22 PM
Steps
Where the oil sender goes into the back of the block, tee it and also add the warning light sender...u need to pull the dizzy to do this.
U will then have oil gauge and warning light.
A 2nd sender can also be wired for the water temp warning.
Fuel warning I dont know..mines wired but have never had the gas low enough to find out...
It is not good practise to get gas that low as it tends to pick up and crap there matbe all in one go, causing float valve problems.
Steptoe is offline
post #4 of 4 (permalink) Old May 24th, 06, 12:06 AM
If your car was originally equipped with console gauges, then the warning lights will not work. The under dash harnesses are both different even though the circuit board is the same.
Camaro buds until the end!!!
Camaro Dave is offline
1967 Console gauges 67FamilyFun Interiors 22 Oct 22nd, 05 05:56 AM
Console Gauges Repo vs Original dschribs Interiors 17 Jul 29th, 03 01:48 AM
WIRING UP CONSOLE GAUGES jdlf Electrical & Wiring 2 Aug 17th, 02 12:45 PM
Dash Lights won't work Kent H Electrical & Wiring 9 Dec 2nd, 01 10:47 AM
Console guage lights kz1000ltd Interiors 2 Apr 18th, 01 06:01 PM
