So I was out driving the other day . . . - Team Camaro Tech
post #1 of 6 (permalink) Old May 22nd, 06, 11:53 PM Thread Starter
I was out driving yesterday, getting my new custom "68GREAT" plate at the DMV, and at one point had to merge left. I gave the guy to the back left good warning and had my blinker on for a few hundred yards, but the guy would not back off. Finally I down shifted and hit the brakes a little and let him go by, wondering what was his damn hurry and putting my arm out to tell him to go ahead. I was kind of upset, but as I pulled alongside him at the light, he waited for me with an open passenger window and told me that when I had been trying to get over, my left turn signal triggered both turn signals. I had been pissed off at him and he was just trying to help.
Before I go screwing around with the wiring myself, has anyone heard of such a thing, and moreover, fixed it? After some testing, I have found that when the right turn signal is activated, only the right front indicator lights up, and nothing happens in back. With the left turn signal, both signals light up and flash. Inside on the gauges, the right turn arrow flashes correctly, but the left turn arrow stays solid. This is new territory for me and I dread electrical problems.
Thanks for any help, and if anyone has any step by step advice on what to try first second and so on to isolate the problem, that would be much appreciated.
Thanks,
mikey1968 is offline
post #2 of 6 (permalink) Old May 23rd, 06, 12:43 AM
Re: So I was out driving the other day . . .
Do you have brake or running lights on the right rear? Could be the bulb or the ground.
Greg U
undee72Z is offline
post #3 of 6 (permalink) Old May 23rd, 06, 06:06 AM
I'd suggest the right tail light assembly is not grounding to the tailpan. Pick up a few 1/4" external star washers at your local hardware store. Put one under at leat 2 of the nuts in each tail light assembly. Also check the bulb sockets and make sure the lil tabs are grounding properly, could just need a lil scotch brite rubbing on the terminals and the hole where the socket plugs in.
post #4 of 6 (permalink) Old May 23rd, 06, 10:25 AM Thread Starter
I will look into that. Yes, it does seem the back right bulb has been loose against the metal grounding. I'll see what I can do and if it changes the problem. Thank you both for the suggestions!
-Mike
post #5 of 6 (permalink) Old May 23rd, 06, 04:12 PM Thread Starter
Checked the light housing and it is grounded (brake lights and emergency work just fine.)
Is there a relay or control switch that determines where the signal goes? It all seemed to go out at once. Again, right front turn indicator still works, as do brake lights. Help!
-Mike
post #6 of 6 (permalink) Old May 23rd, 06, 11:50 PM
If the grounds are good, and the bulbs are working.....the problem might be the switch itself. Do you get a decent "Click" sound when you activate the turn signals from right to left? Grab a test light and turn on the left turn signal. Check the turn signal harness by poking the test light into the harness and see if the test light will blink when you touch the left turn signal wire of the harness. If you have two blinking wires, then the switch is the culprit.
Camaro buds until the end!!!
Camaro Dave is offline
Do you think about your car project all day like me, or am I just eaten up ray moore Camaro Tech 29 Jan 7th, 06 12:58 PM
State Fair Fbody Day 10/15/05 Registration/Release Info!! cytruffle Team Camaro Cruiz-Ins 1 Aug 20th, 05 08:12 PM
July 30th E-town race brings 70 cars to the day! SUPERGONZO Team Camaro Cruiz-Ins 0 Jul 31st, 05 03:25 PM
67 driving lights/headlights gasmoney Electrical & Wiring 0 Apr 9th, 03 10:49 AM
