wiper motor question - Team Camaro Tech
post #1 of 4 (permalink) Old May 24th, 06, 06:46 AM Thread Starter
Harry
dawg's Avatar
ok here goes.
my wipers are working real slow in normal and about normal speed in fast mode.
im thinking the brushes are shot in the wiper motor.
its the original wiper motor and ground is looking good as well as the voltage going to it.
434 stroker
US Navy retired
dawg is offline
post #2 of 4 (permalink) Old May 24th, 06, 08:09 AM
Re: wiper motor question
More likely it needs lubricating. I'd take it apart and grease the armature bearings and the drive gear and bearings. They dry out after 35+ years.
go2fast is offline
post #3 of 4 (permalink) Old May 24th, 06, 12:46 PM
I've taken a few windshield wiper motors apart before and have never seen any worn down brushes even after almost 40 years. Check your transmission linkage for the wipers and see if it might be binding up on something. It might need some lubrication also.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 4 (permalink) Old May 24th, 06, 01:55 PM
Steps
With Dave in the above....
Also check the dribers side strut under the cowl has not been bent...this can happen when an idiot stands up there to sand the roof, puts slight weight on it and throws everything out of alignment. Have struck this a couple times over the yrs....It doesnt take much.
And it is a mother to bend back up....use wooden blocks/wedges to lever back up
Steptoe is offline
Windshield Wiper Pressure Seakane Camaro Tech 13 Jun 13th, 05 11:04 AM
Help with wiper arm removal Obxhokie Camaro Tech 22 May 17th, 05 05:27 PM
windshield wiper motor does not work hobackriver Electrical & Wiring 5 Jul 17th, 03 04:52 AM
Calling all wiper arms! coach420 Body Shop 17 Jun 19th, 02 07:00 AM
wiper motor problem???? hideaway Electrical & Wiring 2 Jan 6th, 02 03:21 PM
