New alternator..how many amps is enough? - Team Camaro Tech
post #1 of 6 (permalink) Old May 24th, 06, 01:45 PM Thread Starter
All I have is head/tail lights, electric fan, radio, and elec. fuel pump. unfortunately I'm not sure on what they all draw. I had a 60 amp and everything "seemed" to work fine..I don't have any other accessories like elect. door locks, A/C, heat, power brakes (if that matters) etc...... How many amps should I go with? 55? 60? 80? 100?
New Jegs chrome 100amp alternator is $99
Duralast 55 amp Reman. with most new parts and LLT warranty is $50.
What to do??
STM69 is offline
post #2 of 6 (permalink) Old May 24th, 06, 01:49 PM
Steps
Re: New alternator..how many amps is enough?
No electic fan, pump...a 60 will more than do, and will handle those also.
In saying that I would gofor at least the 80, preferably the 100.
Steptoe is offline
post #3 of 6 (permalink) Old May 24th, 06, 02:01 PM
Chris
Talking Re: New alternator..how many amps is enough?
This is an area where I like the most I can get. 160 amp alternators are easy to get these days.
Consider this, the typical amp draw of accessories:
Electric cooling fans 15 - 30
Electric fuel pumps 5 - 10
Radio and amps 5 - 10
Head lights 10 - 15
Heater/AC 25 -30
Total 60 - 95
Now consider this, an alternator puts out roughly half of its potenential at idle. A 160 amp unit would put out 70 - 80 at idle. Do the math. I like having lots of power. Just make sure the main wire from the the alternator back to the battery is big enough to handle the load!
If you need a good high amp alternator check these guys out, my preferred supplier:
http://www.motorcityreman.com
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #4 of 6 (permalink) Old May 24th, 06, 02:25 PM
if your battery stays charged and your headlights are bright, you have a big enuf alternator IMHO
post #5 of 6 (permalink) Old May 24th, 06, 04:49 PM
Chris
Not always the case! But can be true!
The stock 63 amp Delco's barely cut it.
Another plus to lots of amperage, I nice HOT ignition!
As stated in the original psot, adding a cooling fan will task a stock alternator at idle and the fan will NOT cool properly.
Good Luck!
Chris @
post #6 of 6 (permalink) Old May 24th, 06, 04:59 PM
Very true Chris.
Also I did not notice he quoted prices for the little as well as the big. If you have to buy one anyway, buy the big one!
Should 160 amps be enough for an alternator? 1968camaro123 Electrical & Wiring 18 Dec 9th, 05 08:35 PM
How many amps do I need? 68SoBe Electrical & Wiring 2 Aug 28th, 04 05:47 AM
New amps for my 69 conv jrager Electrical & Wiring 0 Jun 6th, 03 02:54 AM
Alternator Amps Identification redlines4us Electrical & Wiring 3 Feb 26th, 03 02:12 PM
Low amps Truckinfree Electrical & Wiring 2 May 7th, 02 09:55 AM
