Tic Toc Tac Install - Team Camaro Tech
post #1 of 5 (permalink) Old May 24th, 06, 05:08 PM Thread Starter
Brent
Brentmc's Avatar
Tic Toc Tac Install
I have the tic toc tac and the correct circuit board. I now need to install it in my 68.
Do I just install the tac with the new circuit board and it will work? Or do I need to wire it too?
(I know I need to drill the lens for the clock adjustment knob).
1968 RS/SS Lemans Blue
Brentmc is offline
post #2 of 5 (permalink) Old May 24th, 06, 05:12 PM
john
wagonman's Avatar
Re: Tic Toc Tac Install
you will also need to install a tach lead from your coil.what did you do with the fuel gauge? this is another issue you will need to address.meaning console with gauges etc.........
wagonman is offline
post #3 of 5 (permalink) Old May 24th, 06, 05:16 PM
The tach signal wire was run separately from the top center stud of the tach to the neg side of the coil. That wire does not exist in the dash harness, the factory ran it separate.
Did you get a "guage type" dash harness or a conversion harness?
As compared to a non guage dash harness, the guage harness:
Does not bring the fuel sender wire in.
Does not bring the oil idiot light wire in
Does not bring the temp sender wire in
And brings in the following that are not present at all in a non guage dash harness:
Low fuel
"battery +12v" for the clock
If you have a non guage harness, you should be able to follow the runs on the tach style pcb and determine which pin needs to have battery +12v.
Note that as I modified my standard pcb and harness, I've not studied on the factory dahs guage harness wiring. They may have moved some signals at the dash connector.
Sorry I never finished it, but in your last post, I did put up the pin numbers, wire colors, and functions for most of the non guage cluster connector wires.
post #4 of 5 (permalink) Old May 24th, 06, 06:03 PM Thread Starter
Brent
Brentmc's Avatar
Thanks to both of you.
I will be using a non-gauge harness and can run power to the clock and a tac lead to the coil. It sounds pretty simple to do.
Jim--I will rely heavily on what you have posted on the install and try to get it in this weekend.
Brent
Brentmc is offline
post #5 of 5 (permalink) Old May 26th, 06, 11:09 AM
foreverlookin's Avatar
Brent, I may have a new front harness for a gage conversion around Let me know if your interested and we may be able to work something out.
foreverlookin is offline
Clock problems in Tic Toc Tac deamar Electrical & Wiring 4 Apr 13th, 06 09:44 PM
68 camaro tic toc tach tom weinel Camaro Tech 1 Apr 2nd, 06 07:15 AM
Tic Toc Tach abbeynormal Electrical & Wiring 5 Oct 23rd, 05 11:50 AM
Tic Toc Tach reading double rpm's any adjustments ray moore Electrical & Wiring 8 Oct 18th, 05 05:05 PM
Will my Tic Toc Tac work with an HEI unit? JoshC Electrical & Wiring 4 Aug 30th, 05 03:06 PM
