wiring questions - Team Camaro Tech
post #1 of 8 (permalink) Old May 24th, 06, 08:11 PM Thread Starter
Re: Electrical Basics
jimM im new in here i just got my 68 and i dont know were i stand on the elec . do i just throw a battery in it and see what happens
geenmile68 is offline
post #2 of 8 (permalink) Old May 24th, 06, 08:15 PM
Re: wiring questions
hey, that was cool, managed to move your post off my sticky and start you your own thread, never did that before.
How bout some pics and details on your car? It's complete, I assume? What kinda shape? How long since it ran? pics?
Give us some info.
oh yea, and welcome to Team Camaro, the best place on the internet!
post #3 of 8 (permalink) Old May 24th, 06, 08:25 PM Thread Starter
its a 68 and its been sitting in the garage since 1980 38,000 miles on it original they say it ran when they drove it in there and never turned it back on all numbers match so im happy
post #4 of 8 (permalink) Old May 24th, 06, 08:29 PM
If it was parked that long, you're going to want to read up on bringing it out of long term storage. I'll do some searching and see if I can point you the right direction.
As far as getting electrical power to it, unless it had wires chewed up by mice or something, the wiring should be fine.
Eric
Eric Kammerer is offline
post #5 of 8 (permalink) Old May 24th, 06, 08:31 PM
Here's a start for info on how to safely bring the engine back to life.
https://www.camaros.net/forums/showth...g+term+storage
Eric
post #6 of 8 (permalink) Old May 24th, 06, 08:33 PM
Well if it's been in a garage for 25 years, you're gonna need to at least do some checking first.
Item 1: rodent and animal damage. inspect all the wiring and rubber hoses and things, make sure nuttin is chewed up, no bare wires, no bad fuel lines.
Item 2: Vital fluids. Oil and filter change, make sure something liquid is in the radiator, same with the trans.
Item 3: Brakes. Jack the car up, put it in nuetral, make sure you can turn all 4 wheel, make sure the brake pedal feels normal, inspec the rubber lines at each fron wheel and the center of the rear axle, make sure when you press the brake pedal you can't turn the wheels.
Item 4: Power. put in a new battery. Do not try to start it. Turn the key on and see what works. fuel guage, warning light, exterior lights, everything.
Item 5: Fuel. What gas is in it is gonna be nasty after 25 years. Being a chevy, it likely to start and run anyway, but it wouldn't hurt to go thru and clean the carb, drain the tank, blow out the fuel line, and put some fresh fuel in it.
Item 5: Get the engine ready to run again. This one might be worth a new post in engines.
post #7 of 8 (permalink) Old May 24th, 06, 09:51 PM Thread Starter
thanks guys big help . I feel i did the right thing in joining team camaro thank a lot .More ?? to come
post #8 of 8 (permalink) Old May 24th, 06, 09:56 PM Thread Starter
were do i go to get info on the steps i need to get sarted on my 68 do i try to get it started first or break it down
horn relay wiring questions phishhead Electrical & Wiring 3 Apr 19th, 06 09:29 AM
Electric Temp Gauge install 2 questions on wiring Buildinga55 Electrical & Wiring 1 Feb 20th, 06 07:06 PM
Installing console gauges and wiring. Questions... jumpmaster Electrical & Wiring 7 Aug 23rd, 05 05:36 PM
69 Console Wiring Questions 69-er Electrical & Wiring 4 Aug 14th, 05 08:51 PM
Wiring questions: 69 Camaro 6 cyl ? danrichard Tech 2000 1 Dec 30th, 00 12:02 PM
