how do i install a push button starter switch - Team Camaro Tech
post #1 of 9 (permalink) Old May 24th, 06, 11:30 PM Thread Starter
Question how do i install a push button starter switch
i have a 1968 camaro, i lost the keys for the ignition and rather then replace it i want to put in toggle switches and push button starter switch, trying to go for that nascar dash look. i have all the toggle switches but have no idea what wire go to which switch, i have a 3 post toggle with power acc, ground.
another toggle with power, ground. and the starter button with i guess power and ground...aall i want is to make it so that i can turn the power of the car on and off and start...
palmdale420boy is offline
post #2 of 9 (permalink) Old May 25th, 06, 02:32 AM
Harry
dawg's Avatar
Re: how do i install a push button starter switch
dont do it
#1 the car will be easier to rip off
#2 I think the cops will give you a hassle and give you a fix it ticket.
#3 replacing the switch in the columb isnt that hard
434 stroker
US Navy retired
dawg is offline
post #3 of 9 (permalink) Old May 25th, 06, 03:53 AM
Steps
1/ replace the ignition switch...
And a push button start...if any of the have a car that has one....stock...or can remember when most cars did lol
One turned the switch(key in the center) and pressed a button on the dash.
Simply splice into the ignition ciruit and put the switch in after....AND like NASCAR...over engineer them...high amp rating.
Steptoe is offline
post #4 of 9 (permalink) Old May 25th, 06, 04:02 AM
Remove the purple wire from the "S" terminal on the solenoid.
Get a marine push button switch.
Run a 12 AWG wire from the solenoid battery post to one side of the p/b switch.
Run another length of 12 AWG wire from the other p/b switch terminal to the "S" terminal on the solenoid.
Ignition key to IGN, push the button.
I have one installed on the intake on its own homemade bracket so I can bump the engine over to adjust the valves.
Replacing the ignition switch on a 68 is simple. Remove the ground cable, remove the bezel nut, pull switch down below the dash to unplug the connector. Reasemble in reverse order. Reattach the ground cable. Would be alot safer for you and others.
post #5 of 9 (permalink) Old May 25th, 06, 06:50 AM
I'd also recommend replacing the ignition switch.
To add to everett's directions:
Before the bezel will come off, you need to pull the lock cylinder. Turn the key to accessory, push a paper clip in the hole to depress a lil tab inside, then tue key will turn forther counter clockwise and you'll be able to pull the cylinder with the key.
If you lost the keys, the previous step will probably require screwing a slide hammer into the keyhole and forcibly removing the lock cylinder. This will destroy both the cylinder and the ignition switch.
post #6 of 9 (permalink) Old May 25th, 06, 07:07 AM
Cool Re: how do i install a push button starter switch
I remember the switch being on the floor to the right of the gas pedal. The dimmer switch was on the floor on the left side. Oh! That's right! First gen Camaros have the dimmer switch on the floor, were it belongs.
I also use a switch to bump it over for maintenance work wired into the cowl vent plenum chamber on the fire wall. And I also recommend having a keyed switch with a second hidden switch to control the electric fuel pump you may not have to deter thieves. By the way the first place a thief looks for a switch is under the dash, so that should be the last place it should be hidden.
Larger Dave
Larger Dave is offline
post #7 of 9 (permalink) Old May 25th, 06, 08:13 AM
Thanks, JimM, I forgot.
post #8 of 9 (permalink) Old May 25th, 06, 11:55 AM
You'd probably bend the dash doing that. Better to have it picked or drill it out. A good locksmith could pick that lock in 10 seconds or less.
go2fast is offline
post #9 of 9 (permalink) Old May 25th, 06, 12:39 PM
Take longer for the locksmith to pick than it would to do it correctly.
starter doesn't crank zack 68 Electrical & Wiring 10 Jan 30th, 04 03:58 PM
69' Headlight switch install greenham Electrical & Wiring 1 Aug 20th, 03 04:03 AM
Metering valve, How far should the push button go in? 68 Warren Brakes, Suspension & Steering 4 Apr 25th, 02 05:36 PM
No Neutral Safety Switch? soda Electrical & Wiring 6 Mar 1st, 02 09:47 AM
Ignition switch from button to column budman93 Electrical & Wiring 2 Jun 14th, 01 06:36 PM
