Brake light wire- orange???? - Team Camaro Tech
post #1 of 8 (permalink) Old May 28th, 06, 03:04 PM Thread Starter
Hello-
Can someone tell me if I'm doing this right?
I am setting up a transmission with a lock-up converter from bowtie overdrives.
Directions say to locate the brake light circuit on the vehicle and connect their relay wiring harness to the orange brake light wire.
Is the orange cable located just under the steering column?
BTO says that when the brake pedal is depressed that the converter locks-up.
Am I getting this right?
mykeg11 is offline
post #2 of 8 (permalink) Old May 28th, 06, 08:32 PM
Larry
Re: Brake light wire- orange????
That's a strange way to lock up the converter. Anyway, the white wire going to the brake switch under the column is what you are looking for. It's the "cold" side of the brake switch. There is voltage on it when you depress the brake pedal. The orange wire to the brake switch always has voltage.
Larry
69-er is online now
post #3 of 8 (permalink) Old May 28th, 06, 09:50 PM
Rob
When the brake is pressed, it will UNLOCK the converter.
Rob Rice
RobR is offline
post #4 of 8 (permalink) Old May 29th, 06, 07:58 AM
prostreet69camaro's Avatar
When you bought the trans did they give you a different brake switch. The last one I did came with a switch with 2 sets of contacts. One set for the brake lights and the other set to unlock the converter when the pedal was pushed. They also gave me a print on how to wire it. They might be doing it different now. This was like 3 years ago. If you need the print I can email it to you.
prostreet69camaro is offline
post #5 of 8 (permalink) Old May 29th, 06, 02:04 PM Thread Starter
I'm sorry; yes it says it will unlock the converter.
The trans is a 2004r from Bowtie Overdrives.
Their instructions say to connect to the brake wire which is usually orange.
mykeg11 is offline
post #6 of 8 (permalink) Old May 29th, 06, 05:21 PM
Larry
The only problem with connecting it to the orange wire is that this wire is always hot. Pushing the brake pedal would not do anything. Seems like it needs to be connected to the white wire for any voltage to be produced when the brake switch is activated.
Larry
69-er is online now
post #7 of 8 (permalink) Old May 31st, 06, 10:56 AM
Well Im going to state the obvious..... Call BOWTIE OVERDRIVES. I had a 200r4 before and they were very very helpful when it came down to wiring it up. I am electrically challenged and am not ashamed to admit it. Anyways, give them a call and see if they can clear it up for you.
TOOFUN
mark67ss is offline
post #8 of 8 (permalink) Old Jun 5th, 06, 11:58 AM Thread Starter
Thumbs up Re: Brake light wire- orange????
I called BTO and they confermed that it is the white wire not the orange (which they state in their instructions to look for the orange) which confused me.
As always, thanks for the replies guys!
mykeg11 is offline
Orange Wire/Purple Wire? 69Mike Electrical & Wiring 4 Aug 19th, 05 07:34 AM
rear brake light trouble David Pearson Electrical & Wiring 5 Aug 3rd, 05 03:56 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 07:02 PM
Trun signal brake light problem 496hall Electrical & Wiring 0 Apr 28th, 05 09:24 AM
Looking For Wire For "Charging" Light Go69 Electrical & Wiring 0 Apr 8th, 05 03:33 PM
