!!!95 fuel pump help!!! - Team Camaro Tech
post #1 of 6 (permalink) Old May 29th, 06, 05:31 PM Thread Starter
Exclamation !!!95 fuel pump help!!!
i am having problem finding the pump fuse in my 95 camaro because i lost the fuse box diagram. !!!!!!!!!!!!PLEASE HELP!!!!!!!!!!
BLK95LT1 is offline
post #2 of 6 (permalink) Old May 29th, 06, 05:37 PM Thread Starter
I need help finding the fuse for the fule pump in my 95 camaro.I lost the fuse box cover with the diagram . !!!!!!!!!!!!PLEASE HELP!!!!!!!!!!!!!!!
BLK95LT1 is offline
post #3 of 6 (permalink) Old May 30th, 06, 12:03 AM
Re: !!!95 fuel pump help!!!
The fuel pump fuse I believe is somewhere along the driver's side fender in the engine compartment. I know on the 3rd gen Camaros, certain years have the fuse under the driver's fender instead of under the dash.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 6 (permalink) Old May 30th, 06, 02:54 PM
The fuel pump fuse is not located in the fuse block at all. It is on a separate circuit and the fuse for the pump is located upside down on the inner fender well on the passenger side near the front of the car under a water tight rubber cover.
MwayneH is offline
post #5 of 6 (permalink) Old May 30th, 06, 02:56 PM
The fuel pump fuse is not located in the fuse block at all. It is on a separate circuit and the fuse for the pump is located upside down on the inner fender well on the passenger side near the front of the car under a water tight rubber cover. Haynes Manual has a pix of it
MwayneH is offline
post #6 of 6 (permalink) Old May 31st, 06, 02:32 PM
one post per problem is often enuf!
Fuel Pump lobe on Roller Cams zdld17 Performance 17 May 23rd, 06 06:08 PM
Running with the stock intank fuel pump... RegaMaro Performance 0 Mar 8th, 06 09:25 PM
Need help with stock fuel pump to AN fittings DanW Engine 11 Oct 2nd, 05 10:03 AM
'91 Sierra - fuel pump question HwyStarJoe Bench Racing 14 Jan 3rd, 05 07:18 AM
fuel pump question? hi-po327 Tech 2000 2 Jan 6th, 01 04:47 PM
