Starter/Relay question. - Team Camaro Tech
post #1 of 7 (permalink) Old May 31st, 06, 08:20 PM Thread Starter
Guys,
Got a question for the electric experts. i want to instal some sort of Neutral safety switch in my 6 speed car and like to put a relay so current does not go thru the switch. I was thinking to use the purple wire on the switch and the on the control side of the relay. But I dont want to bring a wire from the battery or junction to inside and to the starter selenoid.
Where is a good source to get power for the relay inside the car? Or which circuit on the fuse box?
67 LS1 T56
67ptcamaro is offline
post #2 of 7 (permalink) Old Jun 1st, 06, 09:37 AM
Re: Starter/Relay question.
Originally Posted by 67ptcamaro
Guys,
Got a question for the electric experts. i want to install some sort of Neutral safety switch in my 6 speed car and like to put a relay so current does not go thru the switch. I was thinking to use the purple wire on the switch and the on the control side of the relay. But I don't want to bring a wire from the battery or junction to inside and to the starter solenoid.
Not sure what you are trying to do, Ill take a guess...You really can't use the fuse box for a power source. If you want a NSS switch thats not directly tied into the starter circuit, and still gets power for cranking from IGN switch, try this using a Bosch style relay
30# Purple from IGN switch
87# Purple to starter "S" terminal
86# jumpered to 30#
87# out to NSS
At NSS switch.......
One terminal to 87# at relay
Other terminal to ground
Car will only start when NSS switch is closed.
Greg U
undee72Z is offline
post #3 of 7 (permalink) Old Jun 1st, 06, 10:01 AM
Gregs layout will work fine with the tko / t56 neutral safety switch. Best bet would be to put the relay under the dash or in the console, someplace the purple wires all ready are, then you only need one new wire, an "active when grounded" to the NSS
post #4 of 7 (permalink) Old Jun 1st, 06, 11:11 PM Thread Starter
Greg U and JimM,
Thanks . I was thinking about it today and tought the same think almost, use the purple wire for controlling the relay and powering it.
67 LS1 T56
post #5 of 7 (permalink) Old Dec 17th, 07, 12:24 PM
Rob
RockinRob's Avatar
Can someone verify the terminal numbers on Greg's list above?
Should the #87 referred to as going "out to NSS" be the #85 instead?
I'm trying to wire my TKO NSS to this relay and want to be sure.
Thanks,
Rob
67 base convertible, GMPP 350/330 HO, TKO500....
Taken around the block for the first time 12/2/07
Finaly getting some paint Sept. 2009
RockinRob is offline
post #6 of 7 (permalink) Old Dec 17th, 07, 12:31 PM
Thanks,
Rob
Yes, it would be 85, which is one end of the coil. If you don't have the NSS closed, the relay won't energize and run the starter solenoid.
onovakind67 is offline
post #7 of 7 (permalink) Old Dec 17th, 07, 12:35 PM
Rob
RockinRob's Avatar
Thanks!
am fm radio question flyers69 Electrical & Wiring 3 Jun 28th, 05 08:31 PM
carb and exhaust question for 67 RS small block Kyson Engine 2 Jun 25th, 05 12:40 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 06:08 PM
Front glass install question Brackneyc Body Shop 12 Jun 11th, 05 10:40 AM
Really off topic paint question Winch Body Shop 6 Apr 26th, 05 08:32 AM
