fuse block - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 5th, 06, 05:10 PM Thread Starter
fuse block
What type of sealer is necessary for a new fuse block before installing?
scottl2 is offline
post #2 of 2 (permalink) Old Jun 5th, 06, 10:17 PM
Re: fuse block
If you bought a new harness, the fuse block should of come with a gasket for between the block and the firewall. If you do not have a gasket, then use some Black silicone sealer and put it around the hole on the fire wall.
Camaro buds until the end!!!
Camaro Dave is offline
Tonawanda DZ Lawrence Shaw Engine 97 Jul 20th, 06 06:05 PM
Fuse block Ing wire to MSD 6AL question 69RS-Yenko Performance 4 Mar 30th, 06 05:34 AM
427 corvette engine P0RCH Engine 2 Aug 29th, 05 09:22 AM
$2000 for a DZ? block ChuckD Tag Team 10 Apr 7th, 05 07:24 PM
Aluminum Block Info zl1num12 Engine 6 Aug 28th, 03 08:09 AM
