Front blinker - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 6th, 06, 10:07 PM Thread Starter
Question Front blinker
68 Camaro coupe; my front blinker just stopped the other day, stays lite but no action. If I remember correctly there is a in-line fuse? the back is working just the front (also front side marker is not blinking). Any ideals? Just want to pass PA inspection and get my wheels on the road....thanks.
john michael is offline
post #2 of 5 (permalink) Old Jun 6th, 06, 11:05 PM
Re: Front blinker
John, Replace the turn signal bulb or the flasher. If the bulb works.....replace the flasher.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 5 (permalink) Old Jun 7th, 06, 04:24 AM
Christropher
Re: Front blinker
I'll refrain from the standard inquisitive remark regarding blinker fluid.
Christropher
...in pieces still.
clwilcox33 is offline
post #4 of 5 (permalink) Old Jun 7th, 06, 05:59 AM
Re: Front blinker
I would check the grounds on that side very closely, back too. Also carefully observe the bulbs with the blinker on, with and without the parking lights on. Sometimes with a bad ground, the blinker will still glow, but if you look close, both filaments are glowing dimly and it won't flash if the parking lights/headlights are also on. Problem is most often a bad ground on the tail light housing.
post #5 of 5 (permalink) Old Jun 7th, 06, 01:28 PM
Paul
Re: Front blinker
I had the same issue with my 67. There are ground wires right off the turn signals that should be checked carefully. They are in a very exposed area and subject to a lot of corrosion.
1967 Camaro RS 350, Tremec 5spd, Hotchkis, Frame off
Bought it
Rebuilt it
Almost done
oakster is offline
Rebuilt Front Suspension - Now Front End Is STILL Too High Rack Man Brakes, Suspension & Steering 7 Apr 3rd, 06 05:19 AM
Front end kit in Canada Mark Yetman Brakes, Suspension & Steering 19 Mar 14th, 04 01:27 PM
Hood adjustments!! Handy69Z Body Shop 2 Mar 13th, 03 04:14 AM
Rear of hood does not line up SSuperman Body Shop 9 Apr 1st, 02 05:00 PM
Hanging Doors ? wesley58_do Body Shop 6 Jan 30th, 02 11:23 AM
