holy boiling batteries Batman !! - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 7th, 06, 10:59 AM Thread Starter
Took the Z on a 100 mile cruise this past weekend, about ten miles from home I started to smell rotten eggs......Opened the hood when i got home to see my new battery boiling from the vents.....Any ideas ? Regulator not workingcorrectly is my thoughtsd but not sure how to check it out for sure.......Any help is much appreciated, not much on the electrical sideof thing...........D
69z302 is offline
post #2 of 4 (permalink) Old Jun 7th, 06, 11:22 AM
Re: holy boiling batteries Batman !!
You will need a volt meter. They are inexpensive and are a must for troubleshooting. They are simple to use. With the car not running the battery volts should be about 12.3-13 for a fully charged battery. With the car running the battery volts should be 13.6 to 14.2 volts if the alternator is charging properly. Sounds like your voltage may be higher. Try a new voltage regulator if your voltage is higher than 14.2. Sounds like the voltage regulator is not properly working to me. I am sure other with more experience will chime in. My suggestion may get you started.
orange 68 is offline
post #3 of 4 (permalink) Old Jun 7th, 06, 11:20 PM
Replace the voltage regulator. The alternator is obviously over charging the battery. Grab a volt meter and check the alternator's output.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 4 (permalink) Old Jun 8th, 06, 04:26 AM
If you used a retro batt. that has holes in the vented caps and slightly overfilled it, when charging it will allow liquid to collect on the batt. top.
It will also corode the snots out of everything around the batt.
Could just be overfilled?
blue ss is offline
