Relays ideas - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 8th, 06, 07:26 AM Thread Starter
Relays ideas
I am in the process of putting a new 140amp 1-wire alternator on my 69. I am putting dual fans w/dual relays as well. I want to put relays on my DSE headlights to. My question is, do any parts store sell relays that have both the male and female connections? The only ones I have seen from AC Delco only have the male end. I am looking for the ones like these.http://www.madelectrical.com/catalog/rly-1.shtml
I do not want to have to solder the wires on the tabs of the relay. If the relay goes bad then I would have to cut the wires and redo.
Any ideas?
502prostreet is offline
post #2 of 5 (permalink) Old Jun 8th, 06, 07:41 AM
Re: Relays ideas
I found a kit in my local auto parts store that has the relay plus the female plug and some wires. Not sure about the quality of the relay though - it's not a Bosch like Mark sells at MAD. All you would have to do is solder the female spade connector on the end of the wire - those are very common - and then plug it on the relay. Ones like the female flat blade ones on this page: http://www.madelectrical.com/catalog/flat-blade.shtml
-Tom
www.camarorestoration.com
cr8zy68 is offline
post #3 of 5 (permalink) Old Jun 8th, 06, 08:22 AM
Re: Relays ideas
http://store.summitracing.com/egnsea...115+4294845465
or
http://store.summitracing.com/partde...5&autoview=sku
Mike - '68 Camaro - aftermarket or modern pretty much everything.
Mkelcy is offline
post #4 of 5 (permalink) Old Jun 8th, 06, 08:36 AM
Re: Relays ideas
I already did what you are planning to do and bought all my stuff here: http://www.terminalsupplyco.com/ I wanted a very clean install so I wanted to avoid using the pigtail setups that everyone sells and was able to get the terminals and sockets separately. I installed everything on a plate behind the driver headlights.
Hammered is offline
post #5 of 5 (permalink) Old Jun 9th, 06, 02:10 PM
Re: Relays ideas
Jameco Electronics has a variety of relays available for automotive applications, and they're very cost competitive. Their web-site is at www.jameco.com. Look in the electomechanical section. Good luck!
LukeWarm is offline
relays goldyiroc Electrical & Wiring 1 May 10th, 06 09:40 AM
Looking for room ideas hideaway Bench Racing 3 Feb 22nd, 06 07:11 AM
Headlight relays questions.... whytry Electrical & Wiring 13 Feb 16th, 06 08:34 AM
relays relays relays HLSASS Electrical & Wiring 10 Oct 3rd, 05 10:06 AM
Long term storage ideas (locations) JHunter Bench Racing 8 Apr 6th, 05 09:18 PM
