1994 Camaro and Power Windows - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 8th, 06, 02:05 PM Thread Starter
Cool 1994 Camaro and Power Windows
Hello,
I have a 1994 3.4L V6 Camaro and the driver's side power window motor and switch went bad at the same time with the window in the down position. Some friends tried to jump the window to move it up (not knowing that the motor was bad at the time of jumping).
Long dtory short, motor and switch were bad, but no power is reaching the fuse block, so no radio and power window power at all. Looked at the fuse box, 15,Amp, 25 Amp, 30 Amp breaker. All good. Under the hood in the fuse box, all good.
Wiring diagram I saw shows that the ACCY switch in the ignition feeds the power to the RAP Relay so that I have that retained power after engine shutoff.
Question is, is there a RAP Relay that can be checked or changed or another Power Window relay somewhere else? I jumped my fuse box and windows and radio work. But, I still want to figure out why no power is reaching them through normal channels.
wmartin is offline
post #2 of 2 (permalink) Old Jun 9th, 06, 04:17 PM
Re: 1994 Camaro and Power Windows
There is a RAP module:
My manual says :"in molded pocket of dash mat, center above floor tunnel " (the picture shows it kinda above the passengers left foot. )
with the ignition in "run" there should be power at terminal D BRN) if not then look at the switch & wiring, there is a fusible link in this scircuit. if there is power in, but not out then check for other wiring problems etc.
TTFN
Mat
SSCARGO
Mat Klemp is offline
67 camaro power windows tonyvol Restoration Corner 1 Aug 1st, 05 01:47 PM
springs in power windows 91 camaro cdlegate Troubleshooting 0 Jul 17th, 05 12:29 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
5th Gen Camaro in 07? 69ProTouring Bench Racing 6 Sep 15th, 03 11:24 PM
