67 RS L/S headlight motor removal. - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 9th, 06, 06:22 AM Thread Starter
Well they were both working just fine the other day. R/S headlight motor works fine and the L/S just quit. I reached my hand around the L/S radiator support and felt the motor and it was extreamly hot after I opened and closed the headlight switch about a dozen times. I going to assume ( I hate using that word Felix Unger ) that the motor is bad. Can I get a quit lesson on the removal of the motor. I hope this doesn't involve the removal of the fender.
Thanks in Advance,
David Brecher
MD396 is offline
post #2 of 4 (permalink) Old Jun 9th, 06, 07:56 AM
GM
Re: 67 RS L/S headlight motor removal.
It's been a few years since taking one apart, remove the grill then there is 2 bolts thru the core support and one to the bracket on the fender holding the headlight assembly in place.
Disconnect the wires and remove as a unit and remove moter on the bench. Check your limit switch first if it did not engage the motor will not operate. And it may be a good idea to test the motor before removing from the car(run direct voltage and ground to motor wires) to be certain it's not a circuit/wiring problem.
72 Nova 454 LS7 ATI Turbo 400 Moser WaveTrac rear
copter is offline
post #3 of 4 (permalink) Old Jun 11th, 06, 09:40 AM Thread Starter
Thanks came out easy.
MD396 is offline
post #4 of 4 (permalink) Old Jun 12th, 06, 02:50 PM Thread Starter
Thanks, New motor solved the problem.
Thanks,
MD396 is offline
67 rs-ignition removal/tip on headlight wiring 67RS383 Electrical & Wiring 3 Apr 3rd, 10 06:17 AM
wiring instructions for 67 rs/ss headlight covers. tommy da man Electrical & Wiring 0 Jan 27th, 06 07:27 PM
WTB Parts for 67 RS Headlight Motor KZOO/67RS/SS Forum Classifieds 3 Dec 1st, 05 06:49 PM
67 rs headlight probs. Mcox Electrical & Wiring 2 Nov 20th, 05 11:12 AM
67 RS Headlight Issues!!! jay'srs/ss Camaro Tech 7 Sep 23rd, 05 12:19 PM
