How do you make these Damn plug wires - Team Camaro Tech
post #1 of 9 (permalink) Old Jun 9th, 06, 03:26 PM Thread Starter
Angry How do you make these Damn plug wires
OK, So after looking at the forum, I decided to go w. Taylor 8mm wires. I bought a set only to find out you have to put your own ends on them. How the HELL do you get the wire through a 90 degree HEI boot?
Do you have to use the recommended crimping tool?
Geez this will never end!!!!
greenham is offline
post #2 of 9 (permalink) Old Jun 9th, 06, 04:20 PM
Charles
Re: How do you make these Damn plug wires
yes, get the recommended crimping tool. i went up to my local auto parts store and ordered one and had it that evening. it makes things go much easier. try putting just a drop of dielectric grease on the end of the wire and also inside the boot and that will help the wire slide into position.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #3 of 9 (permalink) Old Jun 9th, 06, 06:25 PM
The crimping tool is highly recommended. With it, you could pull the connectors off the distributor by the wires with no harm, without, no matter how good a pliers you havem a bit of a pull will separate them.
Here's some pics:
Name:	plug wires 1.jpg
ID:	908   Click image for larger version
Name:	plug wires 2.jpg
ID:	909   Click image for larger version
Name:	plug wires 3.jpg
post #4 of 9 (permalink) Old Jun 9th, 06, 06:59 PM
Harley D
HarleyD67's Avatar
Run the wires through the boot then install the terminal and pull back through. I always make my own wires. It gets real easy after the first couple. Now a set takes me less than a 1/2hr to lay out, cut, and assemble.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #5 of 9 (permalink) Old Jun 9th, 06, 07:08 PM
Just grease em up with the silicone stuff, then "twist" the boot on
post #6 of 9 (permalink) Old Jun 11th, 06, 07:02 AM Thread Starter
Jim, You had the trick... I lubed up the very tip, pushed and twisted it right through the boot. You guys were also right about the crimping tool. I found a pliers type for crimping plug wires from NAPA. very simple to do. All 9 wires were done in 30 min, using everyone's advice. Thanks guys
greenham is offline
post #7 of 9 (permalink) Old Jun 11th, 06, 09:21 AM
I found dish soap works better than silicone grease and you only need a little water to clean up.
Hammered is offline
post #8 of 9 (permalink) Old Jun 11th, 06, 10:50 AM
Harley D
HarleyD67's Avatar
So does WD40.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #9 of 9 (permalink) Old Jun 11th, 06, 11:23 AM
So does KY or its generic form.
deerhunter is offline
Plug wires secondtime z Restoration Corner 10 May 7th, 06 08:00 PM
Spark Plug Wires BW67 Engine 1 Jan 5th, 06 08:49 AM
new spark plug wires 6t8bbc Engine 2 May 31st, 05 05:23 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 07:02 PM
Spark Plug Wires shelbyz28 Tech 2000 5 Aug 26th, 00 09:31 AM
