Head lights - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 9th, 06, 06:45 PM Thread Starter
Head lights
i removed my low beems and replaced them with some euro lights. after the install the left low and high beem stay on and the right low also stays on. the interior hibeem light is on even if i pull the lever to turn off. if i pull it the low bems go dimmer but all the lights stay on butt the right hi beem still stays off? 1983 camaro
dpickl01 is offline
post #2 of 7 (permalink) Old Jun 10th, 06, 02:18 AM
Re: Head lights
You have it wired incorrectly, one of the low beam wires is on the wrong terminal on one of the headlights, and is backfeeding into the highbeams. My guess.
Greg U
undee72Z is offline
post #3 of 7 (permalink) Old Jun 10th, 06, 02:17 PM Thread Starter
Re: Head lights
i only replaced the low beems on each side. i never unpluged the high beem.execpt when i swaped it out. the plug on the low beem hav 3 prongs and the high has to. any other ideas im still stuck on this one .
thank you tho.
dpickl01 is offline
post #4 of 7 (permalink) Old Jun 11th, 06, 12:01 AM
Re: Head lights
Originally Posted by dpickl01
i only replaced the low beams on each side. i never unpluged the high beem.execpt when i swaped it out. the plug on the low beem hav 3 prongs and the high has to. any other ideas im still stuck on this one .
thank you tho.
Did you move any wires around? The low beams have both low and high filaments. If one of the wires is on the wrong terminal, (like having power on the ground terminal) it would backfeed make the dimmer switch ineffective. Start by wiring one headlight at a time to find out the problem
Greg U
undee72Z is offline
post #5 of 7 (permalink) Old Jun 11th, 06, 09:30 PM Thread Starter
Re: Head lights
i think their is a short in one of the wires well i was installing them and turned on i moght of shorted out the headlight and the right side hi beem. Do you think that did it. the plug only plugs in one way .
dpickl01 is offline
post #6 of 7 (permalink) Old Jun 12th, 06, 05:37 AM
Re: Head lights
i think their is a short in one of the wires well i was installing them and turned on i might of shorted out the headlight and the right side hi beam. Do you think that did it. the plug only plugs in one way .
Are you sure the bulbs are correct for your app? You may want to check. Also euro lights pull a little more power, make sure ground wires are tight. Since you are having problems, unplug all headlights and work with one headlight at a time, each time testing the dimmer switch.
Greg U
undee72Z is offline
post #7 of 7 (permalink) Old Jun 12th, 06, 07:37 PM Thread Starter
Re: Head lights
Yes the ground wire was loose work great now thank you
dpickl01 is offline
1967 RS w/ no Hide a way Head lights Bigdaddy69 Restoration Corner 7 Nov 28th, 05 04:24 PM
85' camaro tail lights trevordbs Electrical & Wiring 0 Sep 12th, 05 08:38 PM
adjusting head lights tony -Di Camaro Tech 2 Aug 25th, 05 06:27 PM
crazy lights. Ken/68RS Electrical & Wiring 8 Jul 15th, 04 03:20 PM
fuse box &motor wires an head lights posiblaz Electrical & Wiring 7 May 13th, 04 02:08 AM
