Cancel cam for 67 delux tilt wheel - Team Camaro Tech
post #1 of 1 (permalink) Old Jun 10th, 06, 09:08 AM Thread Starter
Marc
Have had hard time finding correct cancel cam for my 67 with dlux wheel and tilt. The one that came out has a GM p/n 3900512 stamped on it. I ordered a replacement from Rick's that came in GM box labeled 399294 but, the part inside is stamped 399297. Does not fit. I beleive the "flange" for the preload spring should be at the bottom of the cam or farthest away from the wheel. The replacement I was sent from Rick's has the "flange" at the top or near the wheel. The service manual decribes the install as ...cancel cam then spring... Having the flange at the top does not allow the cam to go on before the spring. Anyone know what the correct part number is and where I can get one? Thanks.
mdevereaux is offline
USING A DEGREE WHEEL TO DETERMINE CAM mark67ss Performance 10 Jul 26th, 17 05:33 PM
Cam degreeing...what am I doing wrong? travis Performance 11 Mar 31st, 04 03:44 PM
What do you think of my rendition of a cam degree wheel? JIM68 Performance 10 Mar 22nd, 03 03:58 AM
Got beat by a "F" word, What now? Charles411 Performance 39 Sep 27th, 02 07:13 AM
274xe vs. hot cam on vortecs czar Performance 20 Jul 16th, 02 11:01 AM
