69 RS Back-up Light Wire Location - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 14th, 06, 07:13 PM Thread Starter
Apprentice
Jeff
What is the proper location for the 69 RS back-up light wire grommet coming into the trunk. I have seen it on either side of the bumper bolts. Is there a factory indentation or something that would show if a wire is located properly?
Hackman is offline
post #2 of 5 (permalink) Old Jun 14th, 06, 08:16 PM
Re: 69 RS Back-up Light Wire Location
oooooh that was here just a lil while ago. did you try a search? there was even pictures. I "think" I recall just inboard of the bumper bolts, and yes, there is a dimple.
post #3 of 5 (permalink) Old Jun 15th, 06, 02:37 AM
Charles
if you look at the bumper brace that welds to the tailpanel and the trunk floor that the bumper bolts go through you will see a half circle cut into the brace where it sits on the floor. that is where the pigtail wire goes (1/2" hole). you'll have to look at your taillight harness to make sure you pop the hole on the correct side of the brace as they are interchangeable left to right and have the cuttouts on both sides.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #4 of 5 (permalink) Old Jun 15th, 06, 07:09 AM
click's Avatar
click is offline
post #5 of 5 (permalink) Old Jun 15th, 06, 07:26 AM Thread Starter
Apprentice
Jeff
Thanks for your replies, and picture. I did try a search prior to posting but came up empty - so I consulted the specialists.................. Thanks again.
Hackman is offline
Charging system, external regulator JimM Electrical & Wiring 15 Jan 21st, 20 08:09 PM
gen light wire kilo_00 Electrical & Wiring 14 May 11th, 07 12:19 AM
69 Camaro seat back spring problems Moman Interiors 1 Dec 20th, 05 07:18 PM
Chicago area 69 copo back in 69 TOM BARKLEY Copo & Dealer 2 Nov 4th, 05 06:33 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
