2.8 ign. wire jump. need help - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 20th, 06, 05:54 PM Thread Starter
I recently changed my old set of neihoff wires for a new set.. Not the name brand I wanted but i didnt have alot to spend.. Anyway, on the rear 2 cylinders I can see electricity bouncing onto the block. Just little sparks. Is this a common issue or is there a way to correct this. Thanks.
1987 2.8L MPFI
Craig
CamaroCT is offline
post #2 of 3 (permalink) Old Jun 20th, 06, 06:55 PM
ZZ_430's Avatar
Re: 2.8 ign. wire jump. need help
If the boots aren't damaged, try using some dielectric grease in them. Also spray brake cleaner around the sparkplug holes to clean up any oil that might be there.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 3 (permalink) Old Jun 22nd, 06, 07:49 AM Thread Starter
Thanks for the tip, worked like a charm
CamaroCT is offline
1 Wire - 3 Wire Alternator Question redlines4us Electrical & Wiring 8 Jun 26th, 07 01:16 PM
1969 Camaro Firewall Wire Harmess Phillip_L Electrical & Wiring 3 Jan 23rd, 06 06:10 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 07:02 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
