69 charging "problem" - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 25th, 06, 05:49 PM Thread Starter
Ken
When my 69 350 is idling my lights flicker,and the battery charge voltage reads low(at the battery with a meter) low 13's /high 12's. I think its kinda low for voltage.When you rev the car up slightly the volts climb to the 14's,but come back down when idling.Any thoughts as to if this is a problem or not.
kgmunro is offline
post #2 of 4 (permalink) Old Jun 25th, 06, 06:09 PM
JohnZ's Avatar
Re: 69 charging "problem"
Voltage regulator adjustment/replacement. You should show 13.5-14.5 volts across the battery when the system is charging, and it should charge at idle.
JohnZ
CRG
JohnZ is offline
post #3 of 4 (permalink) Old Jun 25th, 06, 06:37 PM
click's Avatar
check your grounds too, the one next to the battery on the fender lip, the grounds from frame to body below the firewall etc. and the grounds at the volt. regulator.
click is offline
post #4 of 4 (permalink) Old Jun 25th, 06, 06:43 PM
If you just repainted everything, make sure the rad support is getting a good ground too. Since it's rubber mounted, it's only connection is the 4 bolts to the fenders. I ended up attaching my lil ground wire to the rad support instead of the inner fender to get a good ground.
If you go after a new regulator, get a Wells vr715 from autozone. It's a dropin electronic replacement for the mechanical regulator, and costs 1/3 as much to boot!
A certain amount of flickering at idle is not unusual. My voltmeter flashes with the turn signals, for example, using a stock 61 amp alternator and wells reg, voltage goes from 14.5 to 13.5 with the flash of the turn signals at idle.
Charging system, external regulator JimM Electrical & Wiring 15 Jan 21st, 20 08:09 PM
Carb Dates DZ Fool Tag Team 16 Apr 2nd, 06 11:44 AM
69 Camaro Trike edd Gordon Bench Racing 0 Mar 11th, 06 11:53 AM
Installing 69 RS grill in standard 69 how hard rs/rs Camaro Tech 1 Oct 6th, 05 09:34 PM
How do I test my charging system? Darin Imbriaco Electrical & Wiring 2 Sep 3rd, 05 07:32 PM
