16 Volt Q's - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 26th, 06, 05:13 PM Thread Starter
Rodney
16 Volt Q's
Helping a friend work on his race car and he recently switched to a 16 volt system. Currently wiring up an electric fan & popped the fuse on the relay system. Is there a way to choke the voltage down to 12 volts, like a resistor or something? I know there is a box for stuff like this, but trying to stay away from that $85, if possible.
69 RS Camaro (383,700r-4,12-bolt w/4.11s)
79 WS6 Trans Am (406SBC,factory 4-spd,3.23 posi)
87 GTA Pace Car Clone (350TPI,700r4)
97 Bonneville SSE 40th Anniv. (3800 V-6,All Power)
Check out my site at
wildkatz is offline
post #2 of 3 (permalink) Old Jun 26th, 06, 07:31 PM
Re: 16 Volt Q's
Say you want to drop 16 volts down to 12 volts and assume the fan draws 20 Amps continuously. You'd need a resistance of 2v/20A = 0.10 Ohms. The power rating of the resistor would have to be 20A * 20A * 0.10 Ohms = 40Watts.
How big was that fuse the popped? Startup current will always be higher than running current. The 20A running example I gave probably will draw at least 30A for less than a second at startup. A circuit breaker might be a good alternative way of feeding the fan. Many OEMs now days simply use an appropriately sized fusable link for things like fans.
dnult is offline
post #3 of 3 (permalink) Old Jun 26th, 06, 07:39 PM Thread Starter
Rodney
Re: 16 Volt Q's
It was a 25 amp fuse. We were just hooking to the battery to make sure we had it working, using the toggle override wire.
I appreciate the help.
wildkatz is offline
120 volt to 12 volt power supply sneakey pete Bench Racing 6 Mar 1st, 06 01:14 PM
Air Compressor... 110 vs. 220 Volt.. Bowtie Muscle Bench Racing 36 Feb 8th, 06 01:46 PM
CS130 Alternator and Volt guage Rynos67 Electrical & Wiring 17 Nov 18th, 04 07:59 PM
Amp and Volt guage preference and wiring Sleepy-69 Electrical & Wiring 5 Nov 16th, 01 12:27 PM
Need 12 volt switched source!! camaro350 Electrical & Wiring 8 Apr 15th, 01 04:11 PM
