Ignition problem - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 28th, 06, 07:15 AM Thread Starter
Ignition problem
I just finished installing my new motor and 4 speed in my 69 and now I've got a problem with the starter. I've got power to the coil and starter, but when I turn the key to the start position I get nothing. I did the screw driver start test the motor started as it should.
The weird thing is that when I turn the key to start, the lights get very dim. My battery has plenty of juice and starts the engine easily. Maybe I have a short? I also converted the car to a 4 speed and the reverse lockout is disconnected. I thought that might be the problem, so I put the staple shifter in the car connected the lockout and that didn't help.
Any suggestions?
brianjw4 is offline
post #2 of 6 (permalink) Old Jun 28th, 06, 07:50 AM
chris
Re: Ignition problem
what about your neutral safety switch?
cfauver is offline
post #3 of 6 (permalink) Old Jun 28th, 06, 07:56 AM Thread Starter
oh, that's what I meant, not reverse lockout . I hooked up the neutral safety switch on my old auto shifter and it didn't seem to do anything.
brianjw4 is offline
post #4 of 6 (permalink) Old Jun 28th, 06, 09:43 AM
you need to connect the 2 purlpe wires for the neutral safety switch together (to bypass it) or to a neutral safety switch
400bird is offline
post #5 of 6 (permalink) Old Jun 28th, 06, 09:59 AM Thread Starter
I wonder why it didn't work when I connected it to my original auto shifter.... maybe the shifter needs to be grounded for the switch to work properly. I'll try connecting the purple wires and see if that works.
Thanks!
brianjw4 is offline
post #6 of 6 (permalink) Old Jun 28th, 06, 08:31 PM Thread Starter
It was the neutral safety switch, I connected the purple wires and voila.... it started. Thanks for the help.
brianjw4 is offline
2001 Z28 ignition switch/security system malfunction 45Auto Electrical & Wiring 3 Sep 22nd, 05 07:19 AM
Ignition problem 68bbconv Electrical & Wiring 3 Sep 13th, 04 12:57 AM
Ignition switch problem michwalt15 Electrical & Wiring 0 Apr 27th, 03 12:44 PM
Ignition Timing Strange Problem Mean 69 Engine 29 Apr 4th, 02 09:10 AM
Ignition timing problem boomer54 Tech 2000 3 May 24th, 01 05:18 AM
