91 camaro VATS problem - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 28th, 06, 01:18 PM Thread Starter
Need to know how to bypass VATS for 91 camaro
bigd36322 is offline
post #2 of 3 (permalink) Old Jun 28th, 06, 10:40 PM
Send a message via AIM to milehigh67
Re: 91 camaro VATS problem
My 92 corvette had the VATs system in it. Basically the pellet in the key is a resistor. All you have to do is measure the resistance and then buy a resistor of that value. You then simply wire in the resistor permanently which requires you to know how to get into the steering column. Thats a nasty job by itself but the good news is you dont have to go down to far into the column.
There is a lot of good info on the VATS system on the corvette forum. www.corvetteforum.com
Good luck.
1967 Convertible SS 350
milehigh67 is offline
post #3 of 3 (permalink) Old Jun 29th, 06, 06:55 AM Thread Starter
Thanks for info finally figured out that the resister is looping to the VATS and wires from ignition are not hooked backup spent 3 days on a 30 minute job!
car cranks now and cost me $3.39 cents
Non Camaro question -92 GMC EGR problem Jim H Troubleshooting 0 May 2nd, 06 10:00 PM
95 Camaro Fuel Problem Seans95CaMaRo Troubleshooting 3 Apr 29th, 06 09:50 AM
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
Need Help w/"80" Camaro Shifter Problem!!! Robert05 Troubleshooting 2 Feb 6th, 06 10:54 AM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
